Fuel Tank Swap VS Stock tank Quesitons
Hi all... I ogt a 87 stepside and I heard that the gas tanks being on the outside of the frame could be a issue. IS this why people do the gas tank swap to the rear? Is it really needed? I can not really afford a $400 fuel tank and all the work associated with it. Can I make do with the one side tank for now and then convert? Your opinions are welcome..... Ireally dont want to blow up !
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops.
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Fuel Tank Swap VS Stock tank Quesitons
Side tanks have been proven to be no more dangerous than rear mounted tanks. Leave the side tanks and dont worry about it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#3 | ||
Conversion Truck Addicted
Thomas Quote:
Getting Old; Going Broke
If you put a few 1/4 sticks of dynamite beside it, those saddle tanks WILL BLOW UP! Be very careful if you do this, dangerous tanks...
Guys put the blazer tanks in the rear for other reasons. Like suspensions that want that space. Or weight further back for racing. Or to allow the bed side to be smooth. From a driving standpoint the tanks are safe right where they are.
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
78 Big10 454
![]() Join Date: Jul 2008
The only reason I changed to a rear-mounted tank was due to having a single 16.5 gallon saddle tank feeding a 454. I couldn't drive across L.A. without refueling. If I had a factory dual saddle tank set-up, I would have left well enough alone.
as always thanks you saved me some cash !! Maybe down the road I will think about it. why waste $500 if i dont have to.
| Bookmarks |
