Old 06-08-2010, 01:02 PM   #1
'87 Static Slam
'87 Static Slam's Avatar
Rough Idle and Shaking on Acceleration
ok guys, im gonna lay out what happened and i would love to have your thoughts cuz this is KILLIN me!
got truck inspected, failed due to emissions. put a bottle of P-90?? in it, ran the **** out if it at 100 mph for about 10 mins, truck was running GREAT! came back and passed the inspection. went home parked truck for about 2 weeks. next time i started it there was a minor mis, a little bit of a shake on acceleration. parked it. tried to take it out again about a week later, shaking and mis had gotten worse. checked egr, all good. checked pcv, all good. started it again and it was now really shaking bad and totaly missing on acceleration (actually backfired on me). noticed that my coil (stock) was making a clicking noise, replaced it with an accel super coil and changed plugs (all looked fine). made a BIG difference in the shaking, but still was missing a little bit and had a loss of power. took distributor apart last night, all looked good. put it back together fired it up and white smoke started coming from drivers tailpipe after about 5 mins of idle.
this motor is tbi, and only has about 6000 miles on it. this truck was running top notch prior to the inspection day. could the p-90?? have clogged something up? oh, i did put some injector cleaner in it and a full tank of premium after all this happened. do i have a blown or leaking head gasket? i dont have milky oil and my coolant level is the same.
what is making this run like ****?? any ideas? i checked for vaccum leaks and didnt find any either. COME ON GUYS<<<<HELP A BROTHA OUT!!
thanks!
'87 Static Slam is offline   Reply With Quote
Old 06-08-2010, 04:15 PM   #2
jared87350
Re: Rough Idle and Shaking on Acceleration
check your wiering harness. had a broken wire in my 87 and did the same thing , but also stalling out.the wiering harness topside /passenger of the throttle body.Should be a junction of fore or five wires.
jared87350 is offline   Reply With Quote
Old 06-08-2010, 06:36 PM   #3
73chevyman
73chevyman's Avatar
you have to watch out for backfiring due to that is a sign in cases of a whipped cam... my cavalier did this to me..... and what happen was i punched it into a turn and it felt like it jumped out of gear and i over reved it and completely torched the cam hahahaha.... it was running like a volzwagon by the time i got home....... but i could be wrong in this case good luck with your findings..........
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 06-08-2010, 11:27 PM   #4
LiveAnimals
LiveAnimals's Avatar
Did you change the wires? Was the smoke sweet smelling?
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 06-08-2010, 11:50 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Glad you're driving like that in Texas and not around my way!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-09-2010, 06:08 PM   #6
Mayhem.Evol
Thats how we do, ya know..
Mayhem.Evol is offline   Reply With Quote
Old 06-11-2010, 01:42 AM   #7
jrcaprai
What type if Distributor is it? is it an HEI? if so the Control Module may be going out..
or Your Distributor Hold down clamp may be loose and your timing is all over the place...
jrcaprai is offline   Reply With Quote
