Truck Nut
![]() Join Date: Jun 2007
1987 tbi...NOT GETTING FUEL
I have a 1987 4 door 3/4 ton that I an having a fuel problem with. It starts if you prime it, but dies when it runs out of fuel. I do not hear the fuel pump priming, but do hear like a small clank under the hood after the time it would take to prime, like it is trying to get fuel. I did a post search and could not find a clear anwser. The truck has been sitting about a year. I quit driving it because of this problem. I need to get this truck running before it rots away.
Tony Kee Texas Square Bodies |
Re: 1987 tbi...NOT GETTING FUEL
if i remember these have the fuel pump in the tank, take your hand or a 2x4 piece of wood or sumthing and hit the bottom of the tank while someone turns it over, probably the fuel pump itself going out. or take the main fuel line off at the tbi base and have someone crank it and see how long the fuel comes out, if at all. just my .02
First thing to check is the fuel pump relay which is probably the noise your hearing under the hood. You need to check the wiring where the relay plugs in. If you verify that your getting power headed back to tank you need to check the pump. The pumps in Gm vehicles are notorious for going bad on a regular basis.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
their is a oil perssure switch on the motor that controls the the fuel pump also. if the fuel pump fuse is blown the oil pressure switch will turn on the fuel pump when it the oil pump puts out above 4psi. check fuse then check oil pressure switch on motor
I've got the same year & thing happening right now .... I did not get a chance to even look at the crew this weekend.
Ratty 46 |
these trucks also prone to blowing ecm fuse check for power on grey wire at fuel pump and good ground if there is power and ground , bad fuel pump
Truck Nut
I changed the fuel relay. Checked the fuses. Still no go. I will change fuel pump and see what happens. It has dual tanks but of course only one works. On my 87' burb it has just one relay on the pass side firewall, my 87' crew cab has 2 relays?? whats up?
Tony Kee Texas Square Bodies Last edited by texassquarebodies; 06-08-2010 at 08:38 AM. |
#8 | |
high-Tech Red Neck
"He used to be a pretty nice feller, now he's a welder!" |
