06-11-2010, 08:44 AM | #1 |
How do you put cold air in a non-air cst?
I'm getting ready to 'rehab' my '67 CST/20 and would really like to put A/C in it while also liking the idea of keeping it as original as possible. Here's a rub, though. I have a '71 cab with A/C that COULD be swapped but really would what you all think.
The plan is to bring it back to OE - the 283/3ott included... but cold air would be nice. Leaning towards NOT swapping cabs; seems like a lot of extra work.
1969 ES5500 B E A S T 1976 K20 Suburban 1983 C10 'farm truck' 1984 K10 Suburban 1988 V30 Fire Truck 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
06-11-2010, 10:44 AM | #2 |
Active Member
Re: How do you put cold air in a non-air cst?
If you want to keep it as original as possible I wouldn't go with the cab swap. I would look at Cold Air Products or Vintage Air sites to see what they have as under dash installations.
Now if you meant, original "looking" that's a different story. I have been thinking of doing the same thing (cab swap) with my 69 Chevy. Problem is, I haven't located a good enough cab in my area that's in better condition than what I have. |
06-11-2010, 11:43 AM | #3 |
Lots and lots of old, unmolested trucks had dealer add on AC. The fan/ducts are mounted below the dash. The compressor is mounted to the engine. I see them every once in a while on craigslist and the like. For what you're doing I'd just find a vintage correct add on unit and put it on just like the dealer would have in 1967.
A good friend of mine had a beautiful, unmolested 67 with very cold blowing dealer add on AC.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-11-2010, 12:48 PM | #4 |
SWB 4x4 Collector
If you are going towards more original with your build. Don't use the other cab. The 71's are different than all other years where the rear view mirror mounts, and it will be noticeable to any purists. If not being 100% accurate is fine, I would say use the a/c cab and just buy the equipment you don't have and be done. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
06-11-2010, 10:22 PM | #5 |
Thanks much! Glad to hear your thoughts! "Dealer Installed" or Vintage Air sounds good to me. There is already enough body work that HAS to be done, let alone swapping cabs.
06-11-2010, 10:54 PM | #6 |
I've been taking the add-on air out of my 68.It has the under dash evap/blower and a York compressor mounted on the engine.
I have a 70 truck with factory air to use as a donor. To use it,I'll have to do some cutting/filling on the firewall and add the 3 dash vents.The rest is bolt on. Mike. |
06-12-2010, 02:49 AM | #7 |
i think that you should cut all the ac holes in the ac cab 67 72 and then cut your 67 dash then weld in the sheet metal from the other cab that will give you hte holes on the dash then cut the big triangular holes on the firewall and put the ac cab holes on your 67 then the firewall will be ready for the ac unit i have a 67 it used to be a c20 long fleet to but then i changed it into a short fleet it has ac cab aswell
06-12-2010, 07:00 AM | #8 |
Old member
Cut all the holes yourself in the 67 dash as I did in my 71 or cut the dash out of the 71 and put in the 67.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-12-2010, 10:04 AM | #9 | |
Gone to greener pastures
I just read within the last couple of weeks that some AC company was making "retro looking" hang down units Ac units for cars & trucks; but everything was new. It had got me to thinking that would be the way to go with my Chevy. Maybe somebody else knows who I'm talking about.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-12-2010 at 10:05 AM. |
06-12-2010, 11:30 AM | #10 |
Old member
Did a quick google and found .
http://www.southernrods.com/categori...duct-2068.html This says for our trucks. https://www.ackits.com/pc/AMA14315-4...A14315-4197%29
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 06-12-2010 at 11:32 AM. |
06-12-2010, 12:10 PM | #11 | |
Keep in mind that except for the two weekends where I've performed this work, the truck remains fully functional and driveable with heat, just no AC. If you want your non-AC cab to look like an AC cab, all the dimples are there to make the holes you need. You do need do weld a piece in the firewall and cut another piece out. I fabbed my weld in piece by making templates out of the new system and old system, making a paper template, transferring it to metal, and welding it in. Somebody who isn't married, has no kids or doesn't care could probably pull this off in two weekends in a row, not 6 years apart. If you don't have a job you could probably do it over the course of one work week. I grabbed the picture of the AC holes verses non-AC holes off this website some time before 2003. I used photoshop to mark up the marked up picture some time after I did my 2003 firewall mod and posted it here before.
06-12-2010, 12:19 PM | #12 |
For the dash I purchased a complete AC dash from da-burb and intended to cut my old, complete dash out and weld in the AC dash. Then I figured what a waste of time when all you need is three holes. I made templates from the AC dash and transferred them to my non-AC dash. That was a one day job.
06-12-2010, 12:36 PM | #13 |
Old member
That's what I did. The biggest thing was making that first cut. After that it was easy.
06-12-2010, 12:56 PM | #14 |
Seems like a fair bit of hack & slash. Isn't there a vintage cold air "under dash kit" that doesn't require the fabricating?
Looking for a short fleetside bed in the Pacnorthwest/western Canada. |
06-12-2010, 10:36 PM | #15 |
Agreed. It took me 6 years to make that first cut in the dash. Within a couple of hours I had the rest of it all buttoned up.
06-12-2010, 11:49 PM | #16 |
YOU ALL ROCK!
Great insight........ hmmm, I DO have a buddy with a plasma cutter...
06-13-2010, 12:07 AM | #17 |
Your engine is a vacuum pump. When my vaccum pump craps out on me (80% of the work I do is A/C in the summer) I adapt my gauge set charging line to a good manifold vacuum source...brake booster vacuum line is best. It wont put a quick deep vacuum like a vacuum pump will but it does work.
06-13-2010, 08:21 AM | #18 | |
Old member
But then it's not as much fun! Look above your orignal post I listed a couple of links for you.
06-13-2010, 09:53 AM | #19 |
Classic auto air which is what we put in my truck it has been there almost two years blows 37 degrees at the vents and I have zero regrets we have used three of these kits so far....here are some picts of the different parts of it..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 06-13-2010 at 09:56 AM. |
06-13-2010, 10:41 AM | #20 |
Thanks Much!!!
The more info, the better!
06-14-2010, 02:03 AM | #21 | |
