#51 |
Re: Ok guys new idea... EFI need help
The corvette servo will make it shift harder from 1st to 2nd and 3rd to 4th. The servo applies the band in 2nd and 4th gear.
#52 | |
First, you need to make sure the truck is tuned up. Cap, rotor, plugs, wires, fuel and air filters. Most of the time, the coil is fine and does not need to be replaced. Then move on to tuning the carb. Also, you need to check your gearing. 4.10 gears is not helping the fuel mileage any. If you wanted to switch to fuel injection there is a good thread on here covering TBI swaps. http://67-72chevytrucks.com/vboard/s...d.php?t=352321
I can still count my vehicles on two... wait three hands. |
#53 |
i think it has 3.73 in the rear end the qjet carb is really old and ima put the new heads from my uncle a new intake and a new edelbrock carb is 600cfm the right amount for my truck?
#54 |
Still plays with trucks
It is very possible there is a problem in the vacuum control system that the truck 700R4's use for lockup control so the converter is not locking up like it should in 4th. This would drop your mileage a little.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#55 | |
You can do very well with the heads you have with a good truck cam, intake & carb. I would suggest this cam http://www.summitracing.com/parts/CCA-12-234-2/ I put it into my old 81 K20 and even with no overdrive it would manage 16 mpg when with the stock cam it only got 12. With your overdrive and the lock-up functioning you should have no problem getting better mileage than that. The Performer EPS intake and 1406 Edelbrock are just right with this cam too.
#56 |
If you know how to work on Rochesters they are great carbs. But they are very hard to tune. I've only known one person that could and he died a long time ago. The money spent on that could be spent on a new carb.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
#57 | |
On the countless 700R4 vehicles I have owned they drop a very noticeable 300-400 rpm when the converter locks up. It feels like a shift into another gear.
#58 | |
The reason I said that is because that's what the tranny guys told me when mine slipped. After they replaced the converter it went away. The slipping was very noticeable. I guess they could have been wrong too, but that doesn't explain why they fixed it.
#59 | |
If the lockup system is not operational then the trans will still work perfectly fine running around town but the converter just won't lock up when you hit the threshold speed. The vacuum control module the trucks use is prone to failure and I have had to replace three on different square body trucks I have owned to get the lockup feature working again.
#60 | |
http://www.professional-products.com/EFI_3.php I helped a friend drop a new 400 in his '69 camaro, he has this kit on it. After he put about 600 miles on the car and got it dialed in, so it could self learn we went for a ride. We went up through the mountians here, and back almost 200 miles round trip. Tank was full when we left and he topped it back off before we came back to my house. Calculated out to 17.2 mpg. This motor has 500 hp and over 520 ft-lbs. It also has a tremce tko 600 and a moser 3.42 geared rear end and he was not being easy on it. This setup has the potential to give more MPG just crusing on the highway. Here is the video of it on the dyno, with the specs in the comments. While these types of setups are expensive, they will deliever the MPG. This engine would probably be doing good to get 10 with a carb........ The car is a blast too by the way!! ![]()
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 06-13-2010 at 03:13 PM. |
#61 |
Yea i was looking at that kit but i think its cheaper just to stay with a nice new intake carb and the heads
#62 |
It all comes down to how much power you are wanting to make when it comes to an EFI swap and the cost involved.
For under 300 hp you can get away with a stock GM TBI setup by just upping the fuel pressure. Relatively easy to tune with a modified engine but you can also just drop in the drivetrain from an 87-91 Suburban and be done with it. With a bored out TBI setup like the 670 cfm Holley or the aftermarket bored out GM parts you can make even more power with just minor mods to the programming. Much beyond 350 hp will take more air flow & fuel and requires a big jump in cost to something like the FAST system or you could run dual TBI units on a dual quad intake. You can run a modified GM ECM to run dual TBI units. Dynamic EFI has done a great job with this capability. You would have far less into it than the FAST system costs and most everything in your system could be sourced at the local auto parts store when something eventually breaks. You could also just start off with the Dynamic EFI ECM and only run a single TBI unit on your stock intake then save up your money for the dual quad intake and another TBI unit if the power level isn't what you want. The Dynamic EFI ECM will even run E85 fuel too. Pretty nice product. http://www.dynamicefi.com/ I plan on using one on my 68 Camaro when I convert it to EFI.
