Old 06-14-2010, 01:59 PM   #1
bullington
All around good guy
bullington's Avatar
Cargo space with third row
Does anyone have dimensions of the rear cargo area space once you have the third row seat installed?
bullington is offline   Reply With Quote
Old 06-14-2010, 03:25 PM   #2
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Re: Cargo space with third row
I don't have the dimensions, but the original brochures say that there is roughly 40 cubic feet of cargo space back there with the third row in place.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 06-14-2010, 06:31 PM   #3
6772king
6772king's Avatar
mine is 32" to the bottom of the seat and it angles back slightly
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 06-14-2010, 07:32 PM   #4
bullington
All around good guy
bullington's Avatar
Thanks! That is a decent amount of space.
Old 06-14-2010, 07:58 PM   #5
sharpie1972
Yep, 2 dogs and a big cooler! Sharpie
sharpie1972 is offline   Reply With Quote
Old 06-14-2010, 11:52 PM   #6
dougo
dougo's Avatar
If you end up installing a 3rd row seat... and you've installed a larger, or custom gas tank - you might run into issues installing the seat brackets for the center portion, including the seat belt bolts for the two inner belts (the two straps in the center, not the outter belts). I could not get access from under the burb, so I made a custom bracket - which was cheap, and works real well - I can send you a pic if needed.
-Doug
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 06-15-2010, 01:47 PM   #7
bullington
All around good guy
bullington's Avatar
Thanks for the heads up.
