Old 06-15-2010, 03:45 PM   #1
Blazer Dude
Blazer Dude's Avatar
2007 silverado classic question
I have a 07 classic the check engine light came on and it is giving the code
P1400. Does anyone know what the problem is for that code?
Blazer Dude is offline   Reply With Quote
Old 06-15-2010, 06:26 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: 2007 silverado classic question
here is what I could find...
DTC P1400
p1400 is a egr valve malfunction. Not alot of info out there?
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-15-2010, 06:56 PM   #3
bwood
bwood's Avatar
Well I found this listed for a 07 GMC Sierra 1500 (not the classic):
P1400-Cold Start Emission Reduction Control System
Here is where I found it:
http://www.actron.com/code_lookup.php
I could not find the code for the Classic or 06 models.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 06-15-2010, 07:06 PM   #4
bwood
bwood's Avatar
DTC P1400
I found this also, but no verification for GM, P1xxx codes are manufacturer specific codes and can change from manufacturer to manufacturer.
Here a post from a random site that talks about the same codes on a 07 TBlazer (Its a little muddled)
http://www.fixya.com/cars/t4978369-g...p1400_07_6_cyl
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 06-15-2010, 08:28 PM   #5
truckdude239
truckdude239's Avatar
DTC P1400
DIAGNOSTIC INSTRUCTIONS
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Testing and Inspection\Initial Inspection and Diagnostic Overview\Diagnostic System Check - Vehicle
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC DESCRIPTOR
DTC P1400
CIRCUIT/SYSTEM DESCRIPTION
The catalytic converter must be warmed to efficiently reduce the emissions. The cold start strategy is to reduce the amount of time it takes to warm the catalytic converter. During a cold start, the engine idle speed is elevated and spark timing is retarded to allow the catalyst to warm quickly. This diagnostic monitors the following to build an exhaust energy model:
Engine speed
Spark advance
Throttle position
Engine airflow
Engine coolant temperature
Engine runtime
Park/neutral position
Vehicle speed
The actual model is then compared to the expected exhaust energy model.
CONDITIONS FOR RUNNING THE DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0120, P0128, P0200, P0220, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0357, P0358, P0502, P0503, P0506, P0507, P0601, P0602, P0604, P0606, P0641, P0651 are not set.
The engine is at idle with no input from the accelerator pedal.
A cold start has been detected.
The vehicle speed less than 3 km/h (2 mph) .
Airflow per cylinder greater than 80 mg/cylinder
This DTC runs for 15 seconds within the first 2 minutes of start up. This diagnostic runs once per trip when a cold start has been determined.
CONDITIONS FOR SETTING THE DTC
The actual exhaust energy model does not match the expected exhaust energy model.
ACTION TAKEN WHEN THE DTC SETS
The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
DIAGNOSTIC AIDS
Any loading of the engine that lowers engine RPM, such as with partial application of the clutch, during the first 120 seconds of engine runtime may set this DTC.
CIRCUIT/SYSTEM VERIFICATION
Allow the engine to cool. Start and idle the engine for at least 2 minutes . DTC P1400 should run and pass.
CIRCUIT/SYSTEM TESTING
Inspect the air intake system for the following:
Damage, restriction, or improper modification
Dirty or deteriorating air filter element
Crankcase ventilation system for correct operation-Refer to Crankcase Ventilation System Inspection/Diagnosis.
Water intrusion
Vacuum leak and other un-metered air downstream of the mass air flow (MAF) sensor
Intake manifold leak
Inspect the exhaust system for the following:
Water intrusion
Exhaust leak
Damaged, restricted, modified or enhanced exhaust system-Refer to Symptoms - Exhaust System. See: Engine, Cooling and Exhaust\Exhaust System\Testing and Inspection\Symptom Related Diagnostic Procedures\Symptoms - Engine Exhaust
Inspect the engine mechanical for items that could alter the air flow into the combustion chamber. Refer to Symptoms - Engine. See: Engine, Cooling and Exhaust\Engine\Testing and Inspection\Symptom Related Diagnostic Procedures\Symptoms - Engine Mechanical
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
