Old 06-14-2010, 12:53 AM   #26
Scottshotrods
Re: Another IFS/4 link Question
Originally Posted by CHIZZLER View Post
Hey justin thanks for the reply. I did not mark my centerline before i rolled the front out.anyone know from front of frame to center of wheel.
Call me this week I can give you the centerline over the phone I have them at the shop
justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 06-15-2010, 12:52 AM   #27
Wvgearhead
Justin,
Do you use a mustang spindle? I am going to run a 8.8 ford rearend, so instead of drilling for chevy bolt pattern. I was wanting to just go with fords 5 on 4.5.
Aaron
Wvgearhead is offline   Reply With Quote
Old 06-15-2010, 12:56 AM   #28
Wvgearhead
Justin,
More ???? to throw at you. Does your kit come with plates for the frame boxing like tci and the others do?
Old 06-15-2010, 10:10 AM   #29
Scottshotrods
Originally Posted by Wvgearhead View Post
Justin,
Aaron
Yes we do use a mustang spindal and the bolt patterns that we offer are
5 on 4 3/4 chevy
5 on 4 1/2 ford
your choice there on what you want to use.
We also have as a upgrade
5 on 5 bolt pattern
5 on 5 1/2
6 lug
justin
Old 06-15-2010, 10:11 AM   #30
Scottshotrods
Justin,
We do have box plates that come with the ifs when you order.We started
doing this about 4 months ago.
Justin
Old 06-15-2010, 10:32 AM   #31
Wvgearhead
Great. Thanks for the great customer service, and I havent even bought anything yet. lol
Old 06-15-2010, 09:39 PM   #32
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Hey justin. Im also looking at your 4 link kit with bags.maybe a package deal. Mii & 4 link.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 06-15-2010, 10:09 PM   #33
Scottshotrods
On our 4-bar it is more expensive than most.Here is what ours vcome with.
1. 1 1/8 1/4 dom tubing on the link bars they have a right hand and a left hand thread so it is fully adjustable with out taken any bolts apart.
2.The Scotts rodends are cnc machined out of 304 s.s nobody else
machines there rodends like we do.Bushing size is 5/8 and thesd size is 3/4
3.All brackets are lazer cut and bent then tig welded not mig welded.
4.1 1/2 125 wall dom shock crossmember with shock bungs tig welded in place.
5.Our rearend 4 bar brackets are fully tig welded and the rear bag mount
mount is tig welded to the back side of the mount and the lower shock mounts are welded to the bracket as well.
6.The pan hard bar is made out of 1 1/8 1/4 dom tubing and has a right hand
and left hand thread for adjustment.The rod ends are a 3/4 rh thread and a 3/4 left hand thread hime joints.
7.The front 4 bar frame mount brackets are tig welded as well.
8.All hardware is grade 8 bolts
9.Bags are firestone tapered spring and we have re-6 and re-7 slam bags as well we can use.
After this if you are still intrested in a very high quality 4-bar please e-mail me or call me and for doing a package price NO PROBLEM AT ALL.
For some fun I have never thought it would be so hard to sell our products before.lol
Justin
justin@scottshotrods.com
(805)485-0382
Old 06-15-2010, 10:34 PM   #34
CHIZZLER
CHIZZLER's Avatar
Yes the 4 bar kit looks killer. I will be calling this week.can you tell me any details on laying running boards.how much notch is needed.will bags and drop spindles be enough in front.does the crossmember need to be raised.
61-crew cab D-max
Old 06-16-2010, 01:48 AM   #35
Scottshotrods
If you could e-mail me your number I will call myself and explain all to you
in detail and answer all of your questions.
Justin
