Old 06-11-2010, 08:20 AM   #1
Ole Blue 68
Ole Blue 68's Avatar
Help Me Hang a Door
I replaced the passenger side door hinges on Blue last night. The project started off good but then went south when I tried to rehang the door. I spent about an hour trying to get everything lined up right before I had to quit due to darkness.
Is there a way to hang the door with the fender on or am I better off pulling the fender?
If the fender goes, can someone tell me how many bolts there are and where they're located?
Ole Blue 68 is offline   Reply With Quote
Old 06-11-2010, 08:49 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Help Me Hang a Door
you can hang the door with the front fender on, but you need to be very careful not to damage the door/fender. It's always best to remove the striker plate from the cab while aligning doors.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-11-2010, 09:39 AM   #3
c50rob
Much easier in my opinion to hang door with fender removed. Two bolts at top of fender near the hinge, two or three going thru the radiator core support, two each at the top and bottom of your grill, either six or eight connecting innere fender to the fender lip, one connecting the back of inner fender. This is the one that you have to get under the truck to see, it is directly in front of your rocker panel and draws the fender in tight to the cab.
c50rob is offline   Reply With Quote
Old 06-11-2010, 10:45 AM   #4
Ole Blue 68
Yeah, I think I'm gonna have to bite the bullet and take the fender off. I can see myself fiddling with this thing with the fender on for 3 hours and still not having it lined up right.
Thanks for the info!
Old 06-14-2010, 02:55 PM   #5
Ole Blue 68
Update:
Pulled the fender, re-hung the door and then re-hung the fender. It wasn't easy (took nearly 3 hours) but it did help me get the door lined up. Now all i have to do is get the fender back right....
I've got about 3 bolts that still need to get put in to connect the inner and outer fender in the wheel well. Any tips on how to get them lined up better?
Old 06-14-2010, 03:43 PM   #6
Alex Hayley
I find this tool invaluable for lining up holes.
http://www.grainger.com/Grainger/items/2AJB8
Alex Hayley is offline   Reply With Quote
Old 06-15-2010, 12:00 PM   #7
Ole Blue 68
Thanks Alex, I've been using a screwdriver to varying degrees of success. I didn't think about a punch with some more heft to it. I'll check it out.
Old 06-15-2010, 12:04 PM   #8
Alex Hayley
Before you start regarding that tool as a punch, it really is not. It just is named a punch. It is a long, tapered alignment tool. Not a brute force instrument. Tapered is the keyword. Very useful nevertheless.
Old 06-15-2010, 03:43 PM   #9
custom70
custom70's Avatar
I reinstalled my door with the fender on it was a PITA with another person helping me.
custom70 is offline   Reply With Quote
Old 06-16-2010, 10:03 AM   #10
Ole Blue 68
HAHAHA, I just re-read what I wrote in my last post. No worries Alex, I don't plan on using any brute force other than my head on the fender if I can't get these last holes lined up...
Old 06-16-2010, 10:59 AM   #11
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
If nothing else, the alignment tool will work to elongate the holes in the inner fender. Or so I've heard.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
