Old 03-25-2010, 12:13 AM   #1
TheSeeker
Trim holes
I will be filling the trim holes in tomorrow morning, gooing to try a few different things until I absolutley have to get a welder. Ill post pictures of everything as soon as I get the camera back from my wife. Let me know if anyone has done anything to fill trim holes with anything other than a welder. Thanks.
TheSeeker is offline   Reply With Quote
Old 03-25-2010, 08:25 AM   #2
eagleuh1
eagleuh1's Avatar
Re: Trim holes
JB weld.
eagleuh1 is offline   Reply With Quote
Old 06-16-2010, 11:49 AM   #3
gmc1971harwich
gmc1971harwich's Avatar
Re: Trim holes
does jb weld work good? im doing the same thing
gmc1971harwich is offline   Reply With Quote
Old 06-16-2010, 12:20 PM   #4
Kayotic
Kayotic's Avatar
Re: Trim holes
Tap the hole.
Glue a Stainless screw in the hole a few threads, let dry.
cut the head off and grind it down.
I did that when I removed the drip rail on my '86...
I am assuming the holes are fairly small and round.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 06-16-2010, 12:35 PM   #5
Ackattack
Ackattack's Avatar
Re: Trim holes
I've seen bondo used, but I weld mine.
Ackattack is offline   Reply With Quote
Old 06-16-2010, 01:23 PM   #6
Fitz
Re: Trim holes
X2...the only sure way is weld them closed. It does help if you back them up with a copper spoon....less heat so all you need to do to finish is grind the fill flush.
Fitz is offline   Reply With Quote
Old 06-16-2010, 02:52 PM   #7
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Trim holes
http://67-72chevytrucks.com/vboard/s...d.php?t=369713
I've used jb weld on a few small holes, but mine will be hidden by the windshield gasket.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
