Old 04-16-2010, 10:55 PM   #1
justincat
smooth chrome bumper?
Has anyone smoothed the bumper holes on these trucks, and had it rechromed? Or took other chrome bumpers off of other trucks? I want to kept the chrome but I want to do away with the bolts sticking threw. I was thinking about welding a bolt on the back, welding them smooth, and rechroming.
justincat is offline   Reply With Quote
Old 04-16-2010, 11:11 PM   #2
cstm68
cstm68's Avatar
Re: smooth chrome bumper?
heres one on the fesler built 67
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-16-2010, 11:27 PM   #3
justincat
yea cool, thats what im talking about. Is that just a factory bumper smoothed out, and tucked in?
Old 04-16-2010, 11:42 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
It is the smoothing out of the bumper that is the most costly part. Once welded and made to work, then you have to fill the ad spots with material, which in this case has to be a copper or bronze base. Then you sand and smooth until it is perfect. After that the coatings of nickel and chrome go on.
Frank
Old 04-16-2010, 11:50 PM   #5
justincat
could I not just weld bolts on the back of the bumper, fill it up with weld, sand it smooth, and take it to the chrome shop? That would only cost me 200 dollars?
Old 04-16-2010, 11:57 PM   #6
piecesparts
You can, however, there is always a chance of warpage and don't forget those little pits that never seem to fill up when you weld things. If you get lucky, the welding will be all you have to do, but there is a chance that it won't be that easy. I know a guy that had to do the filling process three times and then follow up with sanding and buffing to get his rear bumper smoothed. Chrome is like black paint---if there is a flaw, it will show.
Frank
Old 04-17-2010, 12:15 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
I want to know where you're getting good chrome for $200. I checked locally and at a recommended shop in TN and they want around $1000 per bumper. And they don't want you to sand down the welds. They want to be able to do that so they're responsible for how smooth it is.....
Don't mean that to come out rude....I really want to know where I can get a nice chrome job cheap Normally good and cheap don't mix
Old 04-17-2010, 01:26 AM   #8
justincat
razorback bumper in little rock ar charges 200 some odd bucks per bumper. Im not sure about the quality compare to 1000 dollar chrome job, but I know im not paying that much for it a bumper. I know i can weld, and sand a bumper pretty smooth but im just wondering if I could use some kind of filler that chrome would stick to, to slick it of when im done? If someone who has done this before let me know whats up. thanks
Old 04-17-2010, 05:41 AM   #9
cdowns
cdowns's Avatar
i wouldn't expect much quality from a $200 chrome job and i doubt it would hold up for any length of time
Old 04-17-2010, 09:22 AM   #10
piecesparts
The chroming processes have definitely increased in cost in the last two years. A lot of chrome shops have closed with the imposition of the new federal laws controlling the waste issues.
Frank
Old 04-17-2010, 10:53 AM   #11
mcampbell
Did both of my Blazer bumpers in 93 and it cost me about $100 each. Salt Lake City Chrome straightened them first then I welded the bolts in and took them back for chrome. It was pretty time consuming to get everything smooth. It was long enough ago I can't remember everything we tried to smooth it and still have a filler the chrome would stick to. We tried silver solder at one point. I think in the end it was weld and grind until it was perfect. If you know where to look and get close with the reflection right you can still see a few pits.
They looked fantastic for a few years until a Civic turned in front of me and I t-boned him. I bought new brightwork and a 110 wire feed with the insurance money. I bought a new front and while trying to weld in the bolts have over 20 hours in the 4 bolt holes and now it is so warped it will likely never go on. I have a 220 welder now and need to try one more time. I think by cutting the top of the carrage bolt heads and grinding the sides until there is a 1/16 space between the heads and the bumper holes. Then doing only small puddles I might be able to do it without warping. The earlier heat buildup was mostly from a grinder trying to remove extra buildup. Done right it looks great but I haven't checked chrome cost for quite a few years.
mcampbell is offline   Reply With Quote
Old 04-17-2010, 11:33 AM   #12
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
FWIW... I wanted to smooth mine myself but the chrome shop wouldnt do it unless THEY did the welding and smoothing. (Sherms Chrome in Sacramento)
We also removed the front liscence plate bump. Looks cool, but not cheap.
Tom Vogel is offline   Reply With Quote
Old 04-17-2010, 12:43 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
This information is 100% correct! There are other ways to go about it, but I have researched this through several chrome platers. They all gave the same details if you want quality results that will last. Any thing less will eventually fail.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-12-2010, 11:22 PM   #14
1nice67chevy
1nice67chevy's Avatar
doesnt goodmark sell one for the front?
KEEP ON TRUCKIN!!!
1nice67chevy is offline   Reply With Quote
Old 06-12-2010, 11:29 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
not without the bolt holes.
Old 06-12-2010, 11:39 PM   #16
BIG ORANGE
BIG ORANGE's Avatar
Dam yall are breaking my heart with this info.
I had it all thought out, yeah I'm gonna shave my bumper, hell I'm going to even narrow it a 3/4 of a inch and put my 67/70 short bumper guards on it and send it off to be chrome plated and I will be the chit then!
OMG now what?????
$1000.00 for chroming 1 freakin bumper,,,,,,,,,,,
That bites hard....
I guess I could do 1 and just run a painted bumper!
Then save up my coins and do a 2nd bumper and send it to TN.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 06-13-2010, 08:33 AM   #17
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: smooth chrome bumper?
Not chrome but it sure ant factory either and I have never seen another one like it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-13-2010, 10:07 AM   #18
junkyardjohn
junkyardjohn's Avatar
VERY NICE WORK ANDY. WE DID THAT 6 OR 8 YR.S AGO ON A 55 CHEVY PICKUP. I SAY WE CAUSE I WAS BEING A HELPER IN A BUDDYS ONE-MAN BODY SHOP IN EXCHANGE FOR SOME OF HIS PAINTING & BODY WORK KNOWLEDGE. I'M RETIRED & IT WORKED OUT GREAT FOR BOTH OF US. HE WAS ONE OF THE BEST WELDERS I'VE EVER SEEN, & HE WELDED IN SOME GROUND DOWN CARRIAGE BOLTS, GROUND EM DOWN & POLISHED THEM, LEAVING A LITTLE EXTRA STOCK FOR THE PLATER TO POLISH. FIRST TIME. I DON'T REMEMBER THE COST (IT WAS A CUSTOMERS TRUCK) BUT IT'S BEEN DONE FOR YEARS. NO PROBLEM AT ALL FOR SOMEONE WITH THE TALENTS OR EXPERTIZE. SHOOT I EVEN THOUGHT ABOUT DOING IT ON A PAINTED, MOLDED IN BUMPER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-13-2010, 10:13 AM   #19
Andy4639
Old member
Andy4639's Avatar
Talking Re: smooth chrome bumper?
First off I want everyone to know I didn't do the work I only paid for it. LOL...I wish I could but welding ant one of my strong points. Thanks John for the comments though!!
I know some of you have herd of "Redneck Engineering" in Liberty SC. They build custom motor cycles. They are right down the road from me. They did the welding and cutting for the bumper.
Old 06-13-2010, 05:10 PM   #20
Mondo
Mondo's Avatar
Yeah, I looked into removing the bolts & license plate shape.... too many other things that could be done to the truck for that money.
Now if some aftermarket place took the time to get them manufactured I think everyone would buy it (reasonable price of course).
Mondo is offline   Reply With Quote
Old 06-13-2010, 05:20 PM   #21
MotorHead Lon
MotorHead Lon's Avatar
I dont normally come over here but the title got my attention. I have smoothed my trucks bumpers. I cut the head off of new bumper bolts, leaving the square portion intact. Put the bolt in with the top flush to the bumper and weld up the front side. On the back side I use a fender washer weld to the bumper and around the bolt itself for strength. The chrome shop I talked to told me not to grind the welds, they would rather do it and have control of how smooth the bumper turns out.
Off topic truck but here is my bare metal S-10 bumper after losing the bolts.
88 Chevy C1500, step side, LS swap.
98 Crew Cab Dually, tow rig.
03 Dodge Neon. ECTA Ohio Mile record holder.
MotorHead Lon is offline   Reply With Quote
Old 06-13-2010, 07:42 PM   #22
1nice67chevy
any hot rod shops out ther that i could go to and have them build one of those nice smoothed out bumpers with fog lights
KEEP ON TRUCKIN!!!
Old 06-13-2010, 07:58 PM   #23
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Another thought: What about some of that new-fangled chrome paint? I have seen some stuff done with it that looks pretty freaking close to real chrome... and, you could bodywork the bumper just like a fender to get it nice with less chance of warping.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 06-16-2010, 04:04 PM   #24
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Advanced Plating in Nashville quoted me $1600 during the Good Guys Show.
I would get a NEW 67/68 Front Bumper already Smoothed and Re-Chromed
(They would supply the bumper, do all of the work, and do the Chroming)
AND
I would get a 67-72 Rear Sport Bumper already Smoothed and Re-Chromed
But Still out of my budget at basically $800 Ea.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
