swb 1 piece drive shaft f/s
![]() it came out of swb 71 with a short tail 350 trans $50.00 or $72.00 shipped.
i have 67/72 chevy truck parts f/s. |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Re: swb 1 piece drive shaft f/s
Interested but would like a measurement from centerline of u-joint to u-joint. I bought one of these off of the board before and it came up two inches short when I got it
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
It should be plenty long,especially if it was in a V8 truck.But,if not I`ll step in line next.I don`t have anything to measure,yet.I`m running a SBC/M22 to a 12-bolt.My transmission would be longer than a short shaft TH350,right?I know it bolts directly to the mount on the automatic crossmember.
i will try to measure this 1 today . i have some others about 52" for same price .
![]() Join Date: Aug 2008
I forget...Is a 700r4 the same length as a TH350?
breeh it is 57 1/2 " .
Great, that is what I need. Just to confirm, that is from center eye to center eye? If so, that one has exactly the length that my other one is short.
Assuming the length is what I need, what is my total on the shaft and the groovy diamond tuck dash pad and pleated headliner (also assuming that the headliner is not warped)?
breeh that is 57 & 1/2" center u joint to center u joint but i will double check before you send money. the head liner has paneling for backing not plywood if that makes any drifference. i will also look at it again to see if i think it will stay where you put it when installed. i have paypal if that is how you would like to pay.
Paypal works for me. Let me know the total once you check out the headliner. Paneling is probably more pliable than plywood but I would like it to fit properly and not be bowed.
drive shaft is 57 & 5/8's center to center u joint. head is suppose to be held on by screws with a little washer about every 2 squares . it is bowed but its bowed up toward roof so it should look good and be out of the way when installed. everything would be $155.00 shipped or $120.00 if you don't want the head liner. i will pm you paypal info.
This one is [sold]
i think i have one that is 52" long but i am not sure i have a yoke.
thanks for looking I also measured wrong its more like 47 1/2
