04 chevy tahoe rear axle on 67 1/2 ton coil
ok my idea is to get a 03 to 06 chevy tahoe rear axle with disc brakes added on stock cut the leaf mounts weld coil mounts on cut shock mounts cause coil has the shock mounts on bottom of trailing arms so what i wanna know is the axle tube fatter or skinnier then 67 72 stock and from wheel to wheel is it longer or shorter or the same in advance thanks
#2 | |
Re: 04 chevy tahoe rear axle on 67 1/2 ton coil
Big Red - Now its a SWB!
tahoes have a 4 link with coils, not leaves. I'm not sure what the axle tube O.D. or overall width is but I could measure mine tomorrow. I had also pondered this but I wanted to adapt the tahoe 4 link onto my truck so I could get rid of the leaf setup.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 06-15-2010 at 11:33 PM. |
thank you jacfourteen
you don't need to "add" disc brakes....they were factory equipment after 2000. use the front disc system too and you will have modern (factory) 4 wheel disc with 6 lugs....you could hide them under stock or retro wheels ofr the stealth look. and the wider rear axle will look awesome since gm trucks always have a narrower track width on the back than on the front
![]() Join Date: Nov 2004
I did a quick guestimate of the width hub to hub on my silverado and it looks to be 68-69 inches, which is significantly wider than my 67. You also have to remember the 99+ trucks run rims that have a ton of offset, to have a wider, more stable track width.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
ahhhh sh@# that sucks oh well rear drum and front disc is fine ill just stick with that
