Old 06-17-2010, 05:14 PM   #1
rennalds
cross sill notch
How much do you have to notch the bed cross sill when doing a an under the bed gas tank install? On a 71 long fleetside
rennalds is offline   Reply With Quote
Old 06-17-2010, 05:17 PM   #2
Fitz
Re: cross sill notch
Depends on the tank you plan to use. For an 18 or 22 gal. ECE tank...no notch is required.
Fitz is offline   Reply With Quote
Old 06-17-2010, 05:18 PM   #3
rennalds
Im using the poly tank from brothers
Old 06-18-2010, 04:33 PM   #4
71tahoe
71tahoe's Avatar
If you notch it in half then you can re-weld it to retain the strength. Should give enough clearance.
71tahoe is offline   Reply With Quote
