Old 03-26-2002, 09:21 PM   #1
LMN8R
Question Camaro speedo/tach in our dash?
Can anyone give me a how-to lesson on installing these? I want this info for "Future Reference". Thanks Alot!!
1986 Silverado CrewCab Dually 454 auto.
LMN8R is offline   Reply With Quote
Old 03-27-2002, 12:14 AM   #2
71Chev
71Chev's Avatar
Post
emailed ya instuctions for the tach.
[This message has been edited by 71Chev (edited March 26, 2002).]
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 03-27-2002, 12:24 AM   #3
ryan68
Certified Chevy Man
ryan68's Avatar
Question
Hey 71chev, any chance I can get those instructions too?
68 Chevy CST (327,TH400) 3/5 drop
71 Suburban 4x4 (350,TH350) 33's
Check out my web site!!! http://www.geocities.com/cst68chevy/
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
ryan68 is offline   Reply With Quote
Old 03-27-2002, 12:26 AM   #4
dave's70
Post
Can you fire me a set of those too?
Thanks a lot!
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,and a mild cam
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,a mild cam. also a blazer tank w/bed fill,shaved stake pockets and tailgate
dave's70 is offline   Reply With Quote
Old 03-27-2002, 12:30 AM   #5
71Chev
71Chev's Avatar
Post
done.
Old 03-27-2002, 12:35 AM   #6
ryan68
Certified Chevy Man
ryan68's Avatar
Exclamation
Thanks!!!
Old 03-27-2002, 01:26 AM   #7
LeRoy
Registered truck nut
LeRoy's Avatar
Thumbs up
Me to please
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo,
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev., lwb, utility trailer, 35" tires,
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 03-27-2002, 01:33 AM   #8
Solver
Solver's Avatar
Post
Hey 71Chev I've done 3 of my trucks with that tach but still have yet to figure out the best way to light it.Tried drillng holes at outer edges but then you can see light from passenger side.Just wondering how you lighted yours
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 03-27-2002, 01:54 AM   #9
ColinOpseth
Post
could i possibly get a copy of that for my website? I think that'd be a great article for the Technical Articles section
Just a disclaimer: If you submit it, it becomes property of GMPerformance and although it is your intellectual property (i cannot sell the article for my profit) it would not entitle you to receive profits from GMPerformance proceeds
Not like I make any money anyway (I spend around 50 bucks out of my pocket each month anyway buying stuff for my guys) but I thought i'd put that in
Thanks!
Colin
Webmaster: www.GMPerformance.org
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 03-27-2002, 08:16 AM   #10
71Chev
71Chev's Avatar
Post
Solver the instructions are just something I helped original69 put together to email to whoever. He was the one that did the installation and made the instructions.And they don't say anything about getting the tach lit up.
I have an original tach dash in my truck.
LeRoy & ColinOpseth have mail.
ColinOpseth you should get in touch with member Original69, before you post it on your website. Technically, they are his instructions.
[This message has been edited by 71Chev (edited March 27, 2002).]
Old 03-27-2002, 09:07 AM   #11
beautimus
beautimus's Avatar
Post
can i get a copy of those instructions also?
that's the coolest idea since sliced bread.
thanks
SIMPLY BEAUTIMUS !!!!
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 03-27-2002, 09:37 AM   #12
71Chev
71Chev's Avatar
Post
My Email is down.
The following instructions are from (user) Original69. from the 67-72 board.
Z28 Tach in a 67-72 truck.
Parts needed are the tach, at least 8ft wire. Crimp on ends, 6 nuts same size as the z28
guage studs, grommet, plastic cleaner, drill bit etc. I’m sure I missed something..
Here is an overveiw of the tach install. I used a tach from a 79 Z28 cluster.
1-Dissasemble the rear cover by removing the screws on the edge. I think
there are 8 of them . Set it aside.
2-Take out the black metal plate and set it aside.
3-Take the plastic plate out and you will need to remove the lines in white
that are there. I used a Meguires plastic cleaner and a whole lot of rubbing.
Be careful not to remove any of the other white lines, only the ones where
The tach is going.
4-Get the metal plate, the one with the black side and you will need to
remove the area where the tach will be. I removed just the circle area to
the edge. The tach circumference should be about ½' larger than the circle you are cutting out.
Go slow here and do a good job
5-You will have to trim off the small tab on the tach where it sticks out.
Don’t worry about the small notch that’s there, you won’t see it when
It’s done. I did cut two small pieces off of the edge for the dash lites to
Show thru at night. About ¼'
6-Put the tach where it goes. I had the bend the bottom and top edges with
small pliers before it would fit.
7-Take the tach back out and you will have to do some work to it now.
8-The tach has 3 studs coming thru an insulator plate. This will have to be
removed. I took the 3 nuts and insulator off marking on paper where
wires went. (grnd, pos, tach). You will have to screw the 2 small nuts
on the studs one at a time to DOUBLE NUT them before you cut them.
I used a cutoff wheel and cut close to the top nut. Then back one nut off
and when you do all three hook the three new wires onto the shortened studs.
9-Put the tach back into the cluster and turn it around finding the
best fit in the front. I used sheet metal screws to hold it in. You
can drill a small hole then screw the sheet metal screws in close
along side the tach. This will not show in the front and is good enough
to hold the tach from moving.
10-Now take the rear metal piece and figure out where the tach screws
could possibly hit. It is very close here. If you need room take the
plastic circuit piece off, then use a small ball peen hammer and
hit it a few times to bulge it out some. Be careful you don’t hit
it out too far as the circuit plastic might not want to go back on.
Mine is very tight but I needed the clearance inside.
11-Drill a small hole big enough for the 3 wires and a rubber grommet
to pass thru the rear plate.
12-Check everything before you screw it all back together to make sure.
I also put a few pieces of electrical tape where the studs might hit the
inside of the rear plate.
Old 03-27-2002, 10:18 AM   #13
Fast68Chevy
Fast68Chevy's Avatar
Post
RS camaros also got tachometers
Fast68Chevy is offline   Reply With Quote
