Old 06-20-2010, 10:13 AM   #1
72farmer
Will my thick custom made door panels fit in door panel trim?
I have a 67 that's almost complete.I have custom made door panels out of 1/4" plywood plus of course foam and vinyl uphostery.Are all door panel trim sets the same reguardless where you get them?I worry that when i recieve them the panels will not slide in them because they are too thick.Will someone measure there new ones for me.I have called SKC and their's only measure 1/4" so i worry if they would work.
72farmer is offline   Reply With Quote
Old 06-20-2010, 11:14 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Will my thick custom made door panels fit in door panel trim?
When I built a set of panels a few years ago I cut the foam about 3/4 of an inch short on the top edge so they would slide in the trim. This doesn't really answer your request but if you did yours the same way I can't believe you would have a problem, even with the new trim.
I'm sure someone will chime in with a measurement of the new trim for you.
LockDoc
Leon
