Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-05-2010, 10:25 PM   #176
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
lol. ya, drilling those screws for the clamps was really getting under my skin lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 05-06-2010, 10:32 PM   #177
kev2809
low n' slo
kev2809's Avatar
not a big update but i sanded down and painted my calipers. heres a few pics...
heres a pic off of their website..its actually more grey in person...
heres a pic i took before i painted it...
and some paint!!
-_--_--_ _________
Old 05-15-2010, 04:14 PM   #178
kev2809
low n' slo
kev2809's Avatar
hey guys, i got a quick question. im putting some of my front end stuff back together, just waiting on the rotors which i can get next week. im puttin gmy uca's back on and i kinda forgot how they went lol. i have this pic when i took it all off, and if you notice the right side of the arm is kinda curved, so i was going to put it back on this way..
until i seen this one...(slick67, hope you dont mind!)
if i put it on like this...then mine has the curve on the left side, but the bumpstump hole is also on the left side as the above pic.
when i was putting it back on i was going by the bumpstop hole in that picture until i looked back at the picture i took when i took it off. so was mine on wrong or is there something wrong with the one in the pic?
also, my passenger side arm came with 2 shims (fork style) on the left side, 0 on the right. when i looked at my driver side, it had 0 on the left and 1 on the right. is this ok?
-_--_--_ _________
Old 05-19-2010, 06:29 PM   #179
Burb
Coordinator of Synchronicity
Burb's Avatar
Well mine looks curved to the rear ... but I am not sure if there might be an advantage to swapin them, if it was done on purpose.
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 05-19-2010, 06:43 PM   #180
kev2809
low n' slo
kev2809's Avatar
thats exactly what mine look like. i was waiting on a response so i can tighten them up lol. just waiting on some lca u bolts and my rotors and i can put it all back together. i did get the front bags back in and ran the front lines. working on the gauge line today...maybe some pics later today or tomorrow!
-_--_--_ _________
Old 05-20-2010, 10:57 AM   #181
Burb
Burb's Avatar
Ya gathering some $$$ to finish the front of mine ... still need p/s gear box , and couplings, and some drilled rotors.
... and let me tell ya Kev, after reviewing your build ... you got mad skills.
Rick
Old 05-20-2010, 10:59 AM   #182
Burb
Burb's Avatar
might there be a camber and/or alignment issue with switching the uppers like the Bagged photo shows ?
Rick
Old 06-12-2010, 05:17 PM   #183
kev2809
low n' slo
kev2809's Avatar
i would think so, or something would be out of line when bolting up the spindle.
well some progress! i got everything painted and slapped on to get a look of how it will be on the ground, and to see if my switches and everything are right. thanks to hottrucks for walking me through wiring up the toggle switch and relay!
i did have one problem, the front driver side air bag leaks, so i will have to take that bag down to see where its coming from. also, my rear bags push over A LOT when its aired out. heres some pics!
little before and after..
before the 2 1/2" drop and spindles, and cupped lca's..
after...
driver bag..
passenger bag...
the axle is maybe about an inch off of center, but its still pushed over to far i think. im thinking this double adj. panhard bar isnt long enough. i tried to set it up at about 40 psi in the rear, which im guessing should be ride height. when i fully air everything up, it maxes out at about 70 psi, just raises the fenders about even with the top of tire, if not and inch into the fenders is all this right?
-_--_--_ _________
Old 06-12-2010, 05:28 PM   #184
kev2809
low n' slo
kev2809's Avatar
i still need to fully tighten up the suspension, thanks to scoti for helping me get the right bearings for the rotors also!
i did want to move my rear bags over to get a few more inches and still keep the ta setup..so i was thinking of doing something like this..
or this..
what bag brackets would i need for this?
-_--_--_ _________
Old 06-12-2010, 09:09 PM   #185
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hey Kev look'n good the ony thing is that on you cupped LCA you need to remove the rest of the bump stop bracket ( trust me) and make sure the top edge of he welded in cup is Smooooth...when the bag has air in it there will be some tention against the top edge and it will rub a hole in the bag ( I built the same cup)
also move your track bar to the back of your trailing arm..you need to make that bar as long ad you can because of the amount of travel...do what I did tack it up than bring it to your buddy to weld it up..the longer the bar the less side travel
CHANGE OUT your wires I looked at your pics and it maybe ok today but your going to have an issue later...the last thing you want is to try to get under it and fix something later ( grounds are ok)...
don't forgrt the foil beanie trick either...lol
Keep it up looks good
Hottrucks is offline   Reply With Quote
Old 06-12-2010, 09:49 PM   #186
kev2809
low n' slo
kev2809's Avatar
I threw my original bar away lol. I. may need to send this one back, it seems to short.
just out of curiosity, what did I do wrong with the wires?
-_--_--_ _________
Old 06-13-2010, 07:15 AM   #187
Hottrucks
Hottrucks's Avatar
that wire size is over kill..and isn't designed o be out in the weather it will wick water in...also I think you have slide on connectors...be sure to put some grease on these they will get nasty looking and the connection will be crap...there is not time like not to address this stuff...you can hate me now or later when I say I told you so
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 06-13-2010, 09:56 AM   #188
kev2809
low n' slo
kev2809's Avatar
oh ok. what kind of grease goes on it? I was gonna put that liquid tape u brush on that u were tellin me about.
and u mean the white wire is overkill? not sure what kind it is but its 12 gauge. changing that one out isn't too big of a problem. I would like to color code it anyways. should i change it to 14 gauge?
-_--_--_ _________
Old 06-13-2010, 09:58 AM   #189
kev2809
low n' slo
kev2809's Avatar
anyone have any input on moving the rear bags like that? wondering how much more of a drop I would get.
-_--_--_ _________
Old 06-13-2010, 10:43 PM   #190
Hottrucks
Hottrucks's Avatar
kev that brush on is good where yo make the crimp connectoer but on the part that slides on you should get some dielelectric grease or pput some white grease on them
the main feed to your relay should be a #12 but if your using that red wire to goto your dash switch panel I would question it...think about that flat 4 trialer wire like we talked about...it lays flat and is prebundled so it makes it easy to route though the truck and its color coded for yea
Old 06-13-2010, 11:30 PM   #191
kev2809
low n' slo
kev2809's Avatar
the red wire only goes to the battery. i have the 12 wire running to the battery also for the toggle, and also on the pressure switch.
where could i buy some of that dieelectric grease or white grease?
oh, i also fixed the leak in the front bag, the line was loose. i grew a pair and pushed the line in all the way and it stopped, so now im getting about 120 psi on full air up.
-_--_--_ _________
Old 06-14-2010, 01:16 AM   #192
19723DR
19723DR's Avatar
Lookin' good Kev. If you move the bag in front of the axle you should gain the height of the compressed bag. That should put the trailing arm on the frame. I don't have a bag to measure , but it's about three inches.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 06-14-2010, 03:00 AM   #193
Hottrucks
Hottrucks's Avatar
white grease is the stuff you use on hindges like for your doors...
you should never need the 120 psi...air it up and leave it @ ..say..50 and make sure it stays there
Kev also if you wanted to see how much you could gain pull the bag out but yea the bag is 3" you may run into tire clearance issues...like the sidewall rubbing the outside of the body??
Old 06-14-2010, 10:49 PM   #194
kev2809
low n' slo
kev2809's Avatar
sounds good, ill probably get this panhard bar set first and i really need to roll this thing on some level ground lol. i need to see how much further down the front is than the rear. i think i would rather have a rake look to it than the back squatting....
well right now the tire already goes up into the body area by an inch or 2
so the grease i can find at o reilly right? i just aired it up that high so the bags can have to most pressure i can put in to check for leaks...checked again now and still no loss of air
im gonna talk with jeff at cpp to see if i can change out this panhard bar, its about 4-5 inches too short with it fully extended. and i threw my original one away! gay...
-_--_--_ _________
Old 06-20-2010, 07:28 PM   #195
kev2809
low n' slo
kev2809's Avatar
rolled the truck back today so i get the motor on the stand and start cleaning it up.
heres a shot of the truck again..
now the motor. i was told its a 305 from a 78 malibu, 30k miles on the rebuild. im just gonna clean it up and paint it black and silver, bought some aluminum valve covers and air cleaner, still need to get the basic stuff like water pump, gaskets, plugs, wires, etc. also got a skip white hei distributor going in.
will be cleaning it up this week hopefully and start assembling next week maybe
-_--_--_ _________
Old 06-20-2010, 07:53 PM   #196
ShowSS12
ShowSS12's Avatar
wow kev its looking good.... How much long till you get it running?
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 06-20-2010, 08:02 PM   #197
kev2809
low n' slo
kev2809's Avatar
im hoping within a month. it should be cleaned up and ready to drop in within a few weeks, then i have to pull the old one out. still need a new tank and fuel pump, i dont trust the one thats in there lol
-_--_--_ _________
Old 06-20-2010, 08:25 PM   #198
Hottrucks
Hottrucks's Avatar
Kev chec out the wrinkle black from VHT?? I think thats the brand?? I got it at auto zone?? anyway I used it on my caddy block an it came out great..pics don't do it justice!! you know I dig the black and silver with chrome...my engine theme was to make it look like a Harley engine...and its close!!
Old 06-20-2010, 11:17 PM   #199
project 67 sub
project 67 sub's Avatar
[QUOTE=kev2809;4040047]rolled the truck back today so i get the motor on the stand and start cleaning it up.
that looks really good, cant wait till i can start bagging mine lol. cant wait for mine to sit that low
project 67 sub is offline   Reply With Quote
Old 06-21-2010, 10:30 AM   #200
kev2809
low n' slo
kev2809's Avatar
thanks..the fenders are sitting on my tires so I still have to cut a little out and it should drop a little more
-_--_--_ _________
