Old 06-20-2010, 04:11 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
I need some pictures to help me with installing my Grill Inserts
I got my grill inserts and headlight buckets back from the powder coater and was going to install them.
Does the grill insert go behind the grill or in front. and what is used to hold it in place?
I have the adjustment bolts and springs for the headlight buckets, but am not sure which way they go. I spring does not reach the hole in the bucket.
If anyone has any pictures I think It might help.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 06-20-2010, 08:32 PM   #2
eagleuh1
eagleuh1's Avatar
Re: I need some pictures to help me with installing my Grill Inserts
The spring goes in the crome trim ring that holds the headlight in. Put your bucket on the core support first, with the adjusting screws in the slots, then put the crome ring over spring and turn it to hook spring. Put headlight in bucket, then push crome ring over headlight. It takes a little bit of effort to stretch the spring. Then align screw holes in crome ring with screw holes in bucket and screw down. Sorry, no pics.
eagleuh1 is offline   Reply With Quote
Old 06-20-2010, 10:40 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
Perfect thanks it helps alot.
