BigBlockBobby
Body swap
Can you install a 67 swb body on to a 76 frame?
Bob |
Lemme show you something!!
Re: Body swap
Sure! All it takes is time and some decent fab skills. You could put a fricken Porsche body on a '76 chevy frame-as long as you have a hefty supply of cut-off wheels, welding wire and flap discs.
Now is swapping a '67 body onto a '76 frame a bolt-on affair.....not at all.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Re: Body swap
you can make anything fit with the enough time and money..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
its all about the +6 inches
Re: Body swap
if it's a 2 wheel drive, then I'm gonna say no.
You'd need a body lift on the cab to get it high enough to line up to the bed. I guess you could do it, but it'd look stupid. That would be after fabbing up alll kinds of body mounts and relocating the rear axle, and all kinds of other things. |
Re: Body swap
Yes, it will fit - but you will end up with a truck that looks like its had a body lift.
You'll need to re mount the rear cab mounts, modify the front ones, and you'll end up with a larger than normal gap between the cab & bed, and you'll need to trim the frame horns so the bumper looks right. Follow the link in my signature & you'll see a big purple 4wd we did - it has no body or frame lift - it's a 72 on a 77 4wd frame. Look up a build thread for propanemudtruck, he is doing one right now. |
