Old 05-25-2003, 08:56 PM   #1
orinoco nc
Chevy CST/10 door handle
I have a 69 Chevy CST/10 (350) and on the drivers side door, where you press the button in to open the door, its gone and pushed right in to the inside of the door, i can still see it but it wont come back out and has rotated some. How can this be fixed and cessed? Thanks in advance.
orinoco nc is offline   Reply With Quote
Old 05-25-2003, 09:14 PM   #2
Ironhorse
Ironhorse's Avatar
Most likely you are looking at needing a replacement door handle. When you remove the inside door panel you can access the outer handle which is held in place by two small threaded bolts. The outer handle has the thumb button with a shaft , spring and a plate. When you push on the outer thumb button you push the shaft in and the spring causes it to return as it bottoms by hitting the plate. The shaft pushes on a rotaing arm and plate that actuates the door release rod. Possibly the spring has broken but more likely the retaining crimps on the handle assy' itself snapped and the spring/ plate combination will not function without the resistance. If the crimps are broken my thoughts are you need a new or used outer handle. Have not found a good way to repair broken crimp tabs. Perhaps some one else has more or better info. Been a long time since I had to replace a outer handle, knock on wood. Outer handles can be had at your local salvage or are being re-produced. Hope this helps. Good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 05-25-2003, 09:39 PM   #3
1972ChevyGuy
1972ChevyGuy's Avatar
Howdy from Kannapolis Yea, what he said...You are probably gonna need a new handle with the spring.
1972ChevyGuy is offline   Reply With Quote
Old 05-25-2003, 09:54 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
Orinoco nc I have the new door handle with hardware and gasket and I have used door handels also just which ever way you want to go!I'll send you a PM!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 05-25-2003, 10:24 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup, I also had a handle on life, but mine broke off too!
Welcome to the best forum on the web. These guys (and galls) are nothing short of awsome.
Old 05-25-2003, 10:42 PM   #6
krue
Designated A-hole!
krue's Avatar
Edb told me how to fix that...
First remove the handle by removing door panel and removing two nuts holding handle on.
Then make sure you have all the parts:
button with rod, small spring, flat metal plate with hole for rod to go thru. (You may have to feel around in bottom of door to find these. )
The spring goes over the rod, then the flat plate (which is just to keep spring on) goes under the small tabs.
I was able to reuse my tabs when I fixed both doors on my truck.
If you can't reuse tabs: get some very small screws with nuts at any hardware store and a couple of hose clamps. Trim the end with the screw off of the clamps and drill holes in the handle and clamps to use the clamps to hold the plate on.
Good luck and WELCOME TO THE BOARD!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-25-2003, 11:13 PM   #7
griesel72
griesel72's Avatar
these guys pretty much summed it up, but welcome from kansas, and remember, these guys know everything about our trucks. And the advice is free
david
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 05-26-2003, 12:12 AM   #8
71-longbed
Its Magically Delicious
71-longbed's Avatar
yep this board is a life and time saver ....
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-26-2003, 08:39 AM   #9
orinoco nc
The world of trucks is totally new to me so i ma having t learn everything from scratch. Also being from England its a case of "whats a chevrolet". Currently i am also restoring a 1978 Datsun 280z (sweet car) and i also have the twin turbo version of the Nissan 300zx. (1995) but thanks for letting me join your forum and pick your brains. Jeff
Old 05-26-2003, 01:10 PM   #10
orinoco nc
did a bit of a redneck fix on it. Basically i drilled 4 holes in the side of the handle, (inside) and put 2 small lengths of copper wire thru then and basically twised them on untel they held the plate with the tabs on. Works better than the original.
Old 05-26-2003, 04:17 PM   #11
krue
Designated A-hole!
krue's Avatar
That's the way to go!
www.daveramsey.com
