Old 06-21-2010, 04:14 PM   #1
LandonL
LandonL's Avatar
Compression Test Results..
Alright, with the engine @ operating temperature all plugs removed, I tested the compression. This is kind of in conjunction with this thread -->http://67-72chevytrucks.com/vboard/s...d.php?t=407911
First of all, does anyone know the correct compression for an inline 6?
My results were:
1st---90PSI
2nd--90PSI
3rd--91PSI
4th--91PSI
5th--91PSI
6th--89-90ishPSI
Hopefully you guys will be able to tell me something.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 06-21-2010, 04:58 PM   #2
LandonL
LandonL's Avatar
Re: Compression Test Results..
Does anyone know the correct compression numbers? Im hoping I don't have to do a rebuild
250 L6 .030 over
Old 06-21-2010, 05:16 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That is very low for all cylinders. Was the gauge seated well enough in the plug hole? How many "pulses" did you let the gauge take to get that reading?
Good compression should be around 140 to 150. Decent will be around 120...
Gary
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-21-2010, 05:19 PM   #4
LandonL
LandonL's Avatar
Screwed all the way in, with about 5 bumps. I had the ingition coil wire grounded as well. Any idea what the problem could be??
250 L6 .030 over
Old 06-21-2010, 05:23 PM   #5
fixit-p
fixit-p's Avatar
Did you hold the throttle wide open?
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-21-2010, 05:28 PM   #6
LandonL
LandonL's Avatar
Pedal to the floor the whole time.
250 L6 .030 over
Old 06-21-2010, 05:36 PM   #7
LandonL
LandonL's Avatar
Okay, my helper just told me not pedal to the floor, she had it about halfway..Could that have caused it?
(Never using my mom as a helper again lol)
250 L6 .030 over
Old 06-21-2010, 05:49 PM   #8
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
I've never used the throttle when doing a compression test.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 06-21-2010, 06:12 PM   #9
LandonL
LandonL's Avatar
Alright pedal to the floor didn't make a difference, I shot a little oil in the the plug hole to see if the rings were worn, it didn't increase. So it must be leaking somewhere correct?
250 L6 .030 over
Old 06-21-2010, 06:21 PM   #10
junkyardjohn
junkyardjohn's Avatar
FOR GODS SAKE.. DON'T LET HER READ THIS... TRUST ME.. YOU'RE GONNA NEED HER HELP PLENTY IN THE FUTURE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-21-2010, 06:27 PM   #11
LandonL
LandonL's Avatar
Just wish I knew what the problem was.
250 L6 .030 over
Old 06-21-2010, 06:36 PM   #12
trusty72
trusty72's Avatar
that is low but since they all are close its either the gauge or maybe its just a characteristic of those straight 6 engines. what problems are u having?
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-21-2010, 06:41 PM   #13
trusty72
trusty72's Avatar
i see i read the other thread. atf or marvel down the carb while running, a good tune up, new elctronics in the dist. and drive it is what i would do. and prob clean the carb, recent rebuild doesnt mean a lot.
1972 super cheyenne
1970 Suburb
Old 06-21-2010, 06:59 PM   #14
LandonL
LandonL's Avatar
I was going to try the ATF. By good tune up what all do you think should be done? I was planning on doing the IGNITOR II, and I was gonna do another rebuild on the carb. The gauge was a loaner tools from a brand new Oreilly's, the gauge was never checked out before me.
250 L6 .030 over
Old 06-21-2010, 09:19 PM   #15
GASoline71
GASoline71's Avatar
43 years old... unrebuilt engine... is just plain ol' tired. Prolly needs a re-ring at the least. Or a full on rebuild.
How many miles on this engine? 200,000?
Gary
Old 06-21-2010, 09:24 PM   #16
LandonL
LandonL's Avatar
Only 82k, was my g. grandpa's.
250 L6 .030 over
Old 06-21-2010, 09:39 PM   #17
trusty72
trusty72's Avatar
u never really know what was done to it in the past. a good tune up would be plugs, wires, cap, rotor, check out carb, and the ignitor 2 is a great idea. these are things your gonna buy if you rebuild or not, so what do you have to lose?
1972 super cheyenne
1970 Suburb
Old 06-21-2010, 09:45 PM   #18
'72customdeluxe
Some fresh rotella 10w-30 and beating the tar out of it for an extended length of time might help. 80000 miles isn't extremely high. But it might need a rebuild
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 06-21-2010, 09:49 PM   #19
LandonL
LandonL's Avatar
I have to lose money
Plugs & Wires have been recently done, but I think I might upgrade a MSD kit. Im thinking on one of the offenhauser intakes, what carb would be best 4bbl or 2bbl and how many CFM?
250 L6 .030 over
