Old 06-22-2010, 11:52 AM   #1
rennalds
Sending unit install!! HELP!!!
CAN't get the sender down far enough to let the lock ring catch. First off is there a special tool for tightening the lock ring? Second can I bend the pick up slightly to get it to drop a little bit further? And lastly If I need to can I back out on the flanges screws a little bit and then tighten them back down once I get the lock ring started?
rennalds is offline   Reply With Quote
Old 06-22-2010, 12:25 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Sending unit install!! HELP!!!
You should be able to bend the sender a little to allow it to set all the way down in the tank. Just be carefull you do not go too much and kink it. What kind of tank are you trying to affix the sending unit into? Is it a Blazer Poly tank? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-22-2010, 02:35 PM   #3
rennalds
yeah it is a Blazer poly
Old 06-22-2010, 04:30 PM   #4
Classic Heartbeat
Then you can loosen the screws to aid in the sending unit instalation also. Just mark the way that things are and put them back in the correct orientation. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 06-22-2010, 05:33 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Use some O-ring lube or such on the rubber ring to make it a bit easier.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
