Old 06-15-2010, 12:29 AM   #1
AirSpeed
AirSpeed's Avatar
AC, original or aftermarket?
My 72 used to have AC, I discovered the vent holes while sanding the interior, someone tacked some steel in the vent holes and filled them with bondo (poorly) I bought new side vents and a new center vent to fill the holes. I am thinking of putting AC back in and was wondering if it would be better to scrounge up an original AC box in the junk yard or go with aftermarket parts? I definitely do not want a box hanging down below the dash. I'm not worried about originality I just want some cold air!
Any suggestions? Thanks! Aaron
AirSpeed is offline   Reply With Quote
Old 06-15-2010, 12:32 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: AC, original or aftermarket?
I would go with Vintage Air or Classic Auto air. By the time you find all the factory stuff, you will end up spending just as much money as if you buy a new set-up. If you already had all the original stuff there and intact, I would give fixing it up a try.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-15-2010, 07:46 AM   #3
mrein3
mrein3's Avatar
I would go with original. You can get all the missing pieces from a yard for around $100.
Four $10 cans of R134a at Wal*Mart.
New receiver/dryer for $30 at autoacforum.
New o-ring kit at autoacforum for $8.
Compressor = $200 reman, $10 - $100 out of a bone yard.
New hose assembly for around $80. I got mine at LMC truck.
Adjust your stock POA to work with R134a...
http://www.autoacforum.com/messagevi...&threadid=7567
That will be a heck of a lot cheaper than one of the aftermarket company ones. I think they are around $1000.
Plus if you piece one together yourself you'll learn how the system works so in 10 or 20 years when it breaks down again you can fix it. By then the aftermarket "kit" will be out of production or worse yet the company out of business then what are you going to do to fix that?
I don't work for wlamart, LMC, or autoacforum.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-15-2010, 07:59 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I have to agree the parts are around and pretty easy to come by...the big question is what does your firewall look like the hole for the heater box is diff than the A/C one??
Hottrucks is offline   Reply With Quote
Old 06-15-2010, 08:47 AM   #5
cdowns
cdowns's Avatar
new ones are far more efficient and take less horsepower to run than originals that sucked gas up quickly
Old 06-15-2010, 10:02 AM   #6
big_al_71
big_al_71's Avatar
one company www.classicautoair.com is what I went with and let me tell you this hot florida summer weather it is working amazing.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-15-2010, 01:00 PM   #7
69sixpackbee
Factory system is hands-down better than any of the aftermarket stuff. Been there and done that. If you are going 134A put on a good parallel flow or at least a "picollo" type condenser. Adjust the POA for 134 (stay away from those crap "POA eliminator" valves) and you can upgrade the pump to a Sanden or Seltec. The old A6 is a great pump and hard to beat but the front seals are prone to leakage. The factory system ran continuously as the POA did the work. A6 compressors do not like cycling like TXV systems--that's what will happen if you use the "POA Eliminator". The Sanden I have on my truck runs continually and is a bit easier on gas because it is somewhat more efficient but still does not come close the the output of the old A6 but it works extremely well!. You make sure you have all of the components in place, i.e; water valve, fresh air "flapper" (in the cowl) recirc pot and flap (where the RH kick panel vent is) the controls with good vacuum switch, "Hi" speed relay, cables, vacuum reservoir, hoses, air diverter box, vents etc.
These can be scrounged up fairly cheaply. Yank the heater box and clean out all of the "cooties" from the core and the evaporator. lastly, consider puttin in some screen material under the cowl to cover the grates. This keeps out any future junk. I did this to my truck which was originally an non-A/C cab and anyone would be hard pressed to know that it never was from the get-go.
The factory system gives you the ability to "blend" the temps as well as the air (from outside to recirc) which the aftermarket bolt-on's do not offer.
This is taken from many years of trial and experience.
The choice is yours but IMHO you should go OEM.
Good luck!
Bud
69sixpackbee is offline   Reply With Quote
Old 06-15-2010, 01:40 PM   #8
leddzepp
Moderator
leddzepp's Avatar
This is the sole reason I would go with aftermarket if starting from scratch. The rebuilt A6's are garbage. I have gone through 4 of them because of this and this alone. Three of them did not last more than 6 months. I have bought from several places, including the first which was rebuilt on-site at an A/C shop. It crapped out about a month after the one year warranty expired That is the longest I have had one last. I have never had any other OEM part fail in my factory A/C system. If you decide to go OEM, I would definitely look into swapping out the compressor for a Sanden, as recommended above. Do the POA adjustment as described. I am currently waiting on this one (number 5 and hopefully the last):
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
This is supposed to be a direct replacement upgrade, and I have read nothing but positives on it. It is a NEW, not rebuilt unit. A new A6 will cost more than this.
As far as parts being available in the years to come, Vintage and Classic are used on just about every $$$ hot rod out here where 100+ degree days are normal. Everytime I open a magazine or go to a car show they are all I see. They aren't going out of business anytime soon.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-15-2010, 01:57 PM   #9
Joemomma1
Joemomma1's Avatar
Lets say you go with the original system and have R12 available, is there any benefit to switching to R134a besides where you can get it serviced?
Joemomma1 is offline   Reply With Quote
Old 06-15-2010, 02:14 PM   #10
BIG ORANGE
BIG ORANGE's Avatar
I've been talking with Justin at scottshotrods.com they cnc machine there own bulkheads and give a good discount to board members.
Just mention my name Donnie Snipes from the 67/72 truck forum Big Orange.
Justin has been in the buisness for yrs and had a ton of knowledge of our trucks and the Vintage Air units!
hope this helps!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 06-15-2010, 06:37 PM   #11
69sixpackbee
By all means..if you have R12, keep it R12. That is the best advice I can give anyone. Besides in keeping with freon you can keep the same oil and the original components. If you have not suffered "black death" then that is the best and most economical option. R12 is still readily available (if you have a 509 license to purchase it) and as 134A climbs in price, R12 is becoming more viable of an option.
My $.02
Old 06-15-2010, 08:04 PM   #12
48richard
48richard's Avatar
My 2 cents worth - do it with an OEM system so you can get fresh air. None of the aftermarket systems have fresh air intake, but the GM engineers weren't stupid (yes, I was one of them), nor did GM spend an extra dime if they didn't have to.
I just did mine with OEM cab parts, a Sanden compressor, and a new evaporator just in case. I get about 40 - 42 degree air on a 100 degree day. It did indeed cost about the same as a Vintage Air kit, but the only extra work was cutting the firewall, and that only took a couple of hours.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 06-22-2010, 12:56 PM   #13
primer
primer's Avatar
sorry I didn't see this sooner. I think I have a compressor and cab box around here if that helps influence your decision any.
primer is offline   Reply With Quote
Old 06-22-2010, 11:42 PM   #14
Musclerodz
After installing several original units from scratch, I much prefer Vintage air even with the negative of recirculation only. The hours scrounging parts, chasing down a hundred vaccum leaks, untold hours of installing all the little pieces, and there are some pieces not reproduced to keep these old systems going. It would cost someone twice as much to pay me to install an original unit again over Vintage air.
Mike Redpath
Musclerodz is offline   Reply With Quote
