Old 06-22-2010, 08:35 AM   #1
primetime
primetime's Avatar
was it the brakes?
i have been researching the pull to the right issue when i apply the brakes. after using the 'search' tool here i have not been able to pin point what the final result was for most guys here. is it the spindle thats the issue or is it the caliper? i'm thinking to just replace my spindles with drop spindles anyway and hope i fix the 'pulling to the right' issue.
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 06-22-2010, 08:56 AM   #2
Adams74Chevy
Adams74Chevy's Avatar
Re: was it the brakes?
I'd say brakes would be the most likely to make it pull when braking. The spindle would be all the time.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 06-22-2010, 09:32 AM   #3
dropd80s
dropd80s's Avatar
Fo sho.
dropd80s is offline   Reply With Quote
Old 06-22-2010, 09:15 PM   #4
87GMCChris
87GMCChris's Avatar
If its got relitivly clean brakes, then i would consider calipars. If its pulling to the right when you brake, than the LEFT calipar could be weak. The right is doing more grabing, and pulling it to the right... Just my 2 cents and from experince.
1987 GMC Wrangler - 305TBI/TH400/Duals
1968 Camaro - Resto
2010 Ranger
I only drive truck 6 months a year... Dam Canadian winters.
87GMCChris is offline   Reply With Quote
Old 06-22-2010, 09:25 PM   #5
f.monroe
f.monroe's Avatar
Drive it around the block and then back into the driveway . Jack it up and spin the front wheels . If one is hard to spin , the caliper may be in a bind. Probably the left side . My truck did the same thing and it is usually a collapsed hose from the frame to the caliper . They do not seem collapsed but they are internally .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-23-2010, 12:07 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
Look it up on my page under statistics i have a thread going on about it still have not figured mine out.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-23-2010, 12:07 PM   #7
primetime
primetime's Avatar
wow your truck is just like mine (but much better).
Old 06-23-2010, 12:22 PM   #8
54Caddy
GM Addicted
54Caddy's Avatar
hahah thanks man everything is new on mine runs like a new truck man, just need to get me a new 2 barrel carb.
..Mac’s Garage..
IG:MacsGarage
Old 06-23-2010, 12:32 PM   #9
Turbo85GMC
Turbo85GMC's Avatar
Originally Posted by f.monroe View Post
My truck did the same thing and it is usually a collapsed hose from the frame to the caliper . They do not seem collapsed but they are internally.
x2
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 06-23-2010, 10:44 PM   #10
f.monroe
f.monroe's Avatar
I forgot to mention that if you jack it up and it is hard to spin the wheel or rotor , just crack open the bleeder screw and close it back up . If that makes it easier to turn then the rubber line is most likely collapsed internally. The master cylinder creates quite a bit of pressure so it will push through the collapsed hose but the piston seals in the caliper flex and that is what pushes the caliper piston back a little to release the clamping force . The seals do not create much pressure to push back and will not push through the collapsed line causin the sticking brake . Releasing the pressure with the bleeder screw will release the pressure in the caliper and up the line to the point of the clog .
Frank
