06-23-2010, 08:20 AM | #1 |
another question for you guys...
well, i bought the truck and was told it had a replaced engine. that a new engine and trans were put in truck....
no papers to prove. but friend that knows a little said engine looks newer now the guy said 5.7 the papers in glove have 5.7 circled the sticker in engine bay says 5.0 i was having starting issues and a guy on this forum told me it might be ignition module....so i went to parts store and picked one up. for the 5,7. came home and took mine out. and its the wrong part. went back to exchange it. and the girl said she looked under 50 and the part i needed was there. 57 didnt match. 50 did?? so how can i tell what i have in truck?? engine wise and i guess trans too so far ive been replacing parts as in tune up parts with 5.7 parts. thats what i thought i had and so i asked for those parts any way for me to find out exactly whats under the hoood?? thanks for any help |
06-23-2010, 08:28 AM | #2 |
yeller
Re: another question for you guys...
www.mortec.com will help you determine what engine you have
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-23-2010, 09:08 AM | #3 |
dang its hot
small blck chevy parts interchange so readily that a 5.0 part on a 5.7 or visa versa is common
06-23-2010, 09:46 AM | #4 |
Insert Witty Text Here
Lots of these old trucks have had the old 305 (5.0) replaced with a 350 (5.7). I know mine has, because I'm the one who replaced it.
I would expect the ignition module to be the same for both. If it is '87 and up, though, I couldn't say. They are a little different. Does the truck have overdrive? If so, it is probably a 700R4. If not, it is probably a TH350 (or TH350C with lockup) or a TH400. Look here to identify it. http://www.nastyz28.com/chevy-transm...tification.php Slonaker Last edited by Slonaker; 06-23-2010 at 09:46 AM. Reason: badd speeling |
06-23-2010, 11:28 AM | #5 | |
06-23-2010, 11:30 AM | #6 |
been here longer than Liz
Slonaker, I swapped from 305 to 350 on my 87, used the same ingnition.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
06-23-2010, 11:54 AM | #7 |
i just took a 305 out of mine and but a 350 in it and everything matched up had no issues.
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
06-23-2010, 12:45 PM | #8 |
yeller
looks like they closed it down...too bad.
However, a simple google search resulted... http://www.nastyz28.com/sbchevy/sblock.php Should get the OP, and others who don't google first, pointed in the right direction.
