Old 05-26-2003, 02:33 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What is this
Anyone have any clue as to what this is . It was located in the vaccume line between the brake booster and intake port.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-26-2003, 02:47 AM   #2
Phillip Johnson
Phillip Johnson's Avatar
I would guess a one way check valve.. only a guess.. If you can blow air through one end and not the other, that is what it is. Ive never seen one on any of my trucks but, Ive never really looked....
Phillip Johnson is offline   Reply With Quote
Old 05-26-2003, 02:51 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
You can blow air threw it both way's????????
MEMBER #6377
Project "7DEUCE"
Old 05-26-2003, 04:06 AM   #4
GMCPaul
Looks and sounds like a bad one way check valve.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 05-26-2003, 04:47 AM   #5
73stepside
73stepside's Avatar
it is a vacuum check valve. you can find those at any auto parts store in the help packages. it keeps vacumm in the booster for one application of the brakes after the engine dies.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-26-2003, 10:04 AM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
The check valve in our trucks is the 90 degree plastic fitting at the end of the hose going into the booster.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-26-2003, 10:11 AM   #7
Class of 69
Class of 69's Avatar
Looks like trash can filler now!! It's useless if air goes both ways. Do you have the factory one in the booster grommet too? That one may be bad also, better check it.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-26-2003, 10:41 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
I still have the little whie fitting in the booster. Guess I will have to get a new check valve..THANK'S LUKE
MEMBER #6377
Project "7DEUCE"
