Old 06-19-2010, 06:35 PM   #1
theboxer
Carburator
Finally think i have my Edelbrock 1406 figured out. After lots of tinkering and frustration she is done. My problem was after she got hot and sat, she was very difficult to start. I put on a 1/2" spacer and adjusted the floats on the carburetor. Just got back from a cruise and she starts every time.
theboxer is offline   Reply With Quote
Old 06-19-2010, 07:32 PM   #2
NuBomb
NuBomb's Avatar
Re: Carburator
I've got to adjust the floats on mine as it stalls when I make right or left turns.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 06-20-2010, 11:28 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Carburator
What kind of spacer did you use? I have a phenolic and it worked fine but it was a little pricey IIRC.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 06-22-2010, 10:17 PM   #4
Dusty71blazer
Dusty71blazer's Avatar
Re: Carburator
Mine stalls when I turn left, I have a 1407 (750) that's too big so I just plan to replace it. Should I plan to add a spacer? I have a performer RPM intake. (Mostly stock 350 with a mild cam)
Dustin
'97 Dodge Ram (daily driver)
'71 Blazer (supposed to be a toy... insists on being a project)
'85 Monte Carlo SS (project)
Dusty71blazer is offline   Reply With Quote
Old 06-23-2010, 12:12 AM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Carburator
Where did you set your choke to? Mine seems to start ok, but accelerating is an issue. I think its choking itself out.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-23-2010, 12:26 AM   #6
72Cheyenne350
Re: Carburator
I'm having the same issue with accelerating, my 72 cheyenne feels like it's going to stall and die on me when I try to floor it. I took my truck to have it checked out at a shop they said it might be the camshaft but I've had others say it may be the carb settings.
72Cheyenne350 is offline   Reply With Quote
Old 06-23-2010, 09:49 PM   #7
SeventyOne
Re: Carburator
On my first 71 it would stall/die when making turns or sudden stops - I didn't mess with the float but just raised the idle rpm with the screw on the front.
Not sure if that was correct to do but it did solve the problem.
SeventyOne is offline   Reply With Quote
Old 06-23-2010, 10:12 PM   #8
NuBomb
NuBomb's Avatar
Re: Carburator
I rebuilt my carter AFB (basically the same as the edelbrock) and it idles great and runs great. I thought I adjusted the floats correctly but through reading past posts suspect I must be off a little. I'll try the floats and it doesn't work I'll adjust the idle. I just really like how it is idling right now.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 06-23-2010, 11:33 PM   #9
72Cheyenne350
Re: Carburator
I have an edelbrock 650 on my truck, it does idle a little rough but it starts stalling but it doesn't die when I floor it, when making turns or stopping. I'll try raising the idle rpm and see if that works, thanks for the suggestion.
Old 06-24-2010, 09:30 PM   #10
theboxer
Re: Carburator
I added a wood/phenolic spacer. I also had to re jet and rod the carburetor. You guys with the accelerator problem, I had the same problem. You can adjust the accelerator pump and it will get rid of the hesitation problem.
