Old 06-24-2010, 05:43 PM   #1
Oklahoma
Engine oil cooler
Guys, is there an engine oil cooler that I can get off a newer vehicle that I could use on my 62 C-10 with a 72 350? I'm still trying to get my truck to run at a lower temp. I am still running around 225 on the hot days, and I want it to run cooler, is this wish full thinking or is it possible with the oil cooler to accomplish this?
Thanks Derek
Oklahoma is offline   Reply With Quote
Old 06-24-2010, 06:44 PM   #2
blackedoutharley
Re: Engine oil cooler
An oil cooler will not help with coolant (engine) temp readings.
A well functioning coolant system is the answer. What temp thermostat are you running?
Electric fan or pump mounted? etc......
blackedoutharley is offline   Reply With Quote
Old 06-25-2010, 08:48 AM   #3
Oklahoma
I have a large capacity aluminum radiator, electric fan around 3500cfm, and have changed thermostats from 165,180, and 195, the 180 seems to be the best. I think that the AC that I installed might be having a factor on the cooling issue, but it just amazes me that I have a 97 Camaro with no grill for the air to go thru, and that thing runs nice and cool on the hottest days. I was thinking that an oil cooler would help with keeping the engine a little cooler.
Old 06-25-2010, 10:57 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Have you verified your temp gauge? Put a meat thermometer in the flowing coolant when hot.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-25-2010, 04:29 PM   #5
astrochimp
90's one ton GM van
My 93 has a great factory cooler. Hoses connect under filter, think adapter would bolt on- (engine is a center bolt valve cover SBC).
Don't forget a tranny cooler if you have an auto- they can reduce the load on the radiator.
David
astrochimp is offline   Reply With Quote
