Old 05-26-2003, 02:14 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
Dana 60
Will a Dana 60 rearend hold up in a racing truck?
If so how good will it be and how long will it last?
Thankx
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
Old 05-26-2003, 02:44 PM   #2
Mike C
Mike C's Avatar
That question is too vague. Too many different kinds of "racing", I assume you mean a 4000# drag racer? What kind of gear? What kind of wheel? What kind of power?
The Dana 60 is a very strong rear found in many 9 second drag cars. They convert to flanged axles from full floaters and a 5 lug car pattern. In GMC trucks, there are some 67-68 1/2 tonners that had a 6 lug flanged axle (semi-floater).
It is also popular in rock-crawlers for its strength.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-26-2003, 04:12 PM   #3
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Dana 60s are a very sought out for rear end because of its brute strength. I have heard it being call "bombproof". In my opinion it should be good enough. They are very easy to work on too. I recently put a powr-loc posi in my Dana 60 and it only took 40mins for the whole swap. I love the Dana 60s. Just my opinion.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 05-26-2003, 10:12 PM   #4
Mike C
Mike C's Avatar
HotRod 929 is a little too optimistic on how "easy" a 60 is to work on. To correctly do a diff in an early 60 (before the 80's or so) you need a case spreader to properly pre-load the bearings on the differential. 60's sometimes spin the carrier bearing race is their largest problem. They are more difficult to do a ring and pinion setup on because the differential shims are underneath the carrier bearings. Everytime you need to change shims to adjust backlash, you have to pull the bearings, swap shims, and re-intsall. All of this with the case spreader in place. This is to do it "right." Hopefully HotRod's doesn't have any problems.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-26-2003, 11:35 PM   #5
68gmcjon
Got earplugs?
68gmcjon's Avatar
It would be in my truck. 68' 1/2 ton longbed. It has 3.54 gears and i have around 400 horses.
1968 GMC
Turbo 400 tranny
