Old 06-25-2010, 11:40 PM   #1
Chionos GMs
Chionos GMs's Avatar
Window tint help
I dont know where to post this thread but Im hoping you awesome guys will help me I have a neighbor that I work on his trucks for him and he wants the crappy window tint removed and I need some help. What supplies do I need and some direction on what to do. Thanks guys
My last name is Chiono pronounced key-ono even if my grammar teacher told me Ch dont make a K sound
1995 Ext. cab 350 4wd dd 260,*** miles
1986 1/2 ton swb 305 2wd (melted bearings) SOLD!!
1982 3/4 lwb 6.2 diesel 2wd
1962 Chevy 283 4 speed long step 2wd 2 OWNER GONE!!
Chionos GMs is offline   Reply With Quote
Old 06-26-2010, 12:01 AM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Window tint help
Just pull it off and usually a nice sharp razor blade and some windex should take the glue off. Cars with rear window defogger are a little different( no blade)
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-26-2010, 12:05 AM   #3
Chionos GMs
Thanks. It will be a piece of cake then. cause all the crap I read involved chemicals and heat. Thanks. BTW nice truck in your avatar
Old 06-26-2010, 12:30 AM   #4
85chevylwb
also if it is really really old tint, goo gone works well to help remove old glue residue once the actual tint is scraped off
85chevylwb is offline   Reply With Quote
Old 06-26-2010, 12:33 AM   #5
Chionos GMs
Im goin to use that stuff because the tint is purple now
Old 06-26-2010, 01:04 AM   #6
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
I just removed the tint off of the front windows on my mom's Altima (illegal to have tint on front windows in Cali).. so she got a removal ticket... anywho... I just heated it with a hair dryer... and started peeling a corner, and just keep pulling on it while hitting it with heat.... done... oh and the colder the better to scrape the glue off. If u used a Bissel® hand steamer... that'd help with removing the glue at the same time.
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 06-26-2010, 01:07 AM   #7
Chionos GMs
I was goin to peel and heat too
Old 06-26-2010, 01:58 AM   #8
irishman999
irishman999's Avatar
I found laqure thinner (not sure how to spell it) on a rag makes the glue soft and easily removed with a razor blade.
irishman999 is offline   Reply With Quote
Old 06-26-2010, 02:56 AM   #9
qu1cks1lver56
qu1cks1lver56's Avatar
heat gun, razor blade, and some oops to clean the glue off the windows is how i got the old cheapy tint outta my truck.
qu1cks1lver56 is offline   Reply With Quote
Old 06-26-2010, 08:02 AM   #10
Curly86
You want it there when???
Curly86's Avatar
I always just pull off old tint and use a sharp razor blade and a squirt bottle of water to get glue off
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 06-26-2010, 08:29 AM   #11
Copytech
Got this tip from a pro: soak the tint with Simple Green (or ammonia if you can stand the smell) then cover from the inside with a black trash bag and park in the sun for a couple of hours. Most of the tint and glue will come off together.
DO NOT pull off the film and leave the glue it will be 10x harder to get off. If it tries to separate stop and start scraping.
Best of luck.
Copytech is offline   Reply With Quote
Old 06-26-2010, 09:04 AM   #12
MONTEZ
Best of luck.
X2 But soapy water works just as well without the smell. Use johnson's baby shampoo and water in a spray bottle, helps to put a trash bag on the outside too.
MONTEZ is offline   Reply With Quote
Old 06-26-2010, 10:12 AM   #13
Ghastlyone
Ghastlyone's Avatar
Yep, the tint guy I've used for years does the same thing for removal. The trash bag trick works perfect.
Ghastlyone is offline   Reply With Quote
Old 06-26-2010, 03:07 PM   #14
Chionos GMs
Couple hours!! Can I do all three windows at once or is it better to do one at a time? Thanks guys
Old 06-26-2010, 11:13 PM   #15
CaliDude76
CaliDude76's Avatar
Personally, I would do em one at a time... unless you get someone to help you with the other windows... if your in a hurry... my tint guy had his niece help pull off tint.... but he used a handheld pressure steamer... and it peeled right off, real clean too.. glue and all.. he heated.. she pulled...
CaliDude76
Old 06-26-2010, 11:21 PM   #16
Chionos GMs
I will have to get someone to help me because I really dont want his truck here for longer than it needs to be
