06-24-2010, 12:44 PM | #1 |
C10 CLUB Y QUE!
Drop spindels
How do you know when you come across some at the junkyard
06-24-2010, 12:58 PM | #2 |
Re: Drop spindels
The way I tell is by looking where the "shaft" is positioned from the rear. When I say "shaft" I mean where the rotor sits. The stock spindles put it right above the lower ball joint mount. Its should be in the middle from the upper and lower ball joint mounts for drop spindles. I hope you can understand what Im trying to say, looking from back of the spindle.
06-24-2010, 02:04 PM | #3 |
C10 CLUB Y QUE!
Re: Drop spindels
So what your saying the shaft should be closer to the bottom
And stock have them in the middle of the spindel I have a complete 84 frontend just and wanted to check if has drop spindels if I'm lucky Last edited by Sick5; 06-24-2010 at 02:11 PM. |
06-24-2010, 02:12 PM | #4 |
C10 CLUB Y QUE!
Re: Drop spindels
Anyone got any pics of drop spindels
06-24-2010, 03:12 PM | #5 |
Re: Drop spindels
06-24-2010, 03:19 PM | #6 |
C10 CLUB Y QUE!
Re: Drop spindels
Stock bottom and drop middle gotcha.. Thanks
06-25-2010, 11:11 PM | #7 |
C10 CLUB Y QUE!
Re: Drop spindels
I've found spindle for 100 but fits73-to 87
Should I get them even if it says 73-87 |
06-25-2010, 11:13 PM | #8 |
Re: Drop spindels
What suspension do you currently have in the front?
06-25-2010, 11:34 PM | #9 |
C10 CLUB Y QUE!
Re: Drop spindels
stock but I have that 84 clip I can use parts for
06-26-2010, 01:02 AM | #10 |
C10 CLUB Y QUE!
Re: Drop spindels
if i do get them what will i need r'to change on my stock clip
06-26-2010, 10:13 AM | #11 |
Re: Drop spindels
Take the upper and lower control arms and spindels from the 84 front end and bolt them to the crossmember thats in the truck now. Then all you have to worrie about is tie rod ends. There are several threads on this, just hit up the search button.
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw |
06-26-2010, 01:32 PM | #12 |
C10 CLUB Y QUE!
Re: Drop spindels
tie rod end i have for the 84
and a steering box |
06-27-2010, 12:13 AM | #13 |
60-66 Nut
Re: Drop spindels
Just switch to the '84 upper and lower control arms, steering linkage, steering box, and braking system. Of course you'll need the rotors and calipers as well.
06-27-2010, 12:23 PM | #14 |
C10 CLUB Y QUE!
Re: Drop spindels
