Old 06-27-2010, 02:29 PM   #1
gopokes
gopokes's Avatar
Weld rear cab supports?
I am in the process of cutting my frame down from long to short and wondered if there is anything wrong with just welding the rear cab supports back on instead of using grade 8 bolts. Most of the other builds I've read have shown to bolt them back up. Just seems a little easier to weld them in, I don't think I will be moving them again any time soon.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 06-27-2010, 03:48 PM   #2
trusty72
trusty72's Avatar
Re: Weld rear cab supports?
dont see why not, just may be obvious from a resale point of view if they get down and look.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-27-2010, 04:58 PM   #3
gopokes
gopokes's Avatar
I don't ever intend on selling my truck anyway. Even if that day did come I wouldn't try to say it was an original shortbed. Thanks for the reply.
Old 06-27-2010, 05:13 PM   #4
KrazyRay
KrazyRay's Avatar
You can install it with some quality plug welds where the old rivets used to be and grind it flush to make it look good.
KrazyRay is offline   Reply With Quote
Old 06-27-2010, 08:53 PM   #5
gopokes
gopokes's Avatar
That's kind of what I had planned, was also thinking some more welds around for extra strength. So you think just the plug welds would be strong enough? I'm not terribly worried about the looks, more the strength.
Old 06-29-2010, 10:13 AM   #6
KrazyRay
KrazyRay's Avatar
Good plug welds will be strong enough. That's with proper joint prep and penetration on the welds. You can even add a bead on the top which will be hidden. I think welds around the sides will stick out.
