steering gear seal picture
anyone know where to get this seal? It is the small one inside the big nut.
1961 Apache short step. |
Re: steering gear seal picture
saginaw box right? I got mine from carquest, but I bet NAPA has it also. I just used a pick to pull the seal. You should also do the output shaft seal as well and that should cover you.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
thank you. Did you have to pull the box?
You can do it in the frame or out. I pulled mine because I painted it at that time. I would say other then a few extra bolts to fully remove from frame, it was nice using the bench instead of working around the frame and sitting on the ground.
Matt
