#1 | |
Re: '01 Duramax A/C compressor no worky
here is a link to GM clutch diagram You may want to look here to http://aircondition.com/tech/ Last edited by mbgmike; 06-27-2010 at 03:46 PM. |
#2 | |
I miss this truck.
Fuses are good, relay is good. No obvious problems with the control panel. jumping the low switch didn't do anything. Any tips on checking the other two sensors? EDIT: Scratch that, I DO know now that the compressor will turn. I jumped 12V to the clutch and it engaged. I'm sort of at a loss why it isn't getting a signal to run, but it's not.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. Last edited by Tynee; 06-27-2010 at 04:26 PM. |
![]() Join Date: Jan 2003
If I were at the same point, I would find a diagram for the AC controls and check out the AC relay and terminals. Make sure the relay is getting the signal to come on. I don't have a diagram for your 01 though.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
