![]() Join Date: Apr 2008
stearing vibration/grown noise
so i used my dads 04 ext cab 4x4 this weekend and i am not impressed. when you turn to the left it has a vibration and power stearing noise. you can feel it in the wheel and it feels like it fights you to turn. but when you turn it back to the right not a single noise or anything nice and smooth! is it the pump or the gear box? it does it every time!!
![]() Join Date: Sep 2005
Re: stearing vibration/grown noise
probley the gear box going out
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
![]() Join Date: Sep 2001
If there's enough play in a steering box then yes, even if you have enough fluid pressure gear lash could make it seem like it's fighting the pump. However, if the pump is cavitating (air in the fluid causing the pump to run inneficiently) it can do this too. Check the fluid and see if you have bubbles. Also check the color of the fluid. When your hoses start to wear out they'll dissolve and change the color of the fluid, which can cause some funny behavior with the pump over time.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
| Bookmarks |
