Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-20-2010, 11:15 PM   #26
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: Pardon the new guy... My plowrig build
Originally Posted by jeremy zander View Post
Nice..Helpers are always good..!!!
Even if it does take an extra couple minutes to complete a job! Or find that 9/16 deep well again...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 06-20-2010, 11:17 PM   #27
propanemudtruck
Originally Posted by Dieselwrencher View Post
Nice progress!
Thanks Dieselwrencher! I know it's minimal progress compared to most of the nice builds going on around the site, but I am proud of what has come of this. Still working on that deadline in 3 weeks to be in the sand dunes!
-Kevin
Old 06-20-2010, 11:23 PM   #28
propanemudtruck
The wood box is interesting, nicely done. Building a 63 K10 for plowing industrial/ commercial sidewalks.
Thank you. It was a project from my first plow truck. The original bed in the 92 Dodge fell apart literally. I unbolted the mounts, sawzalled the front panel of the box, the sides fell off and I rolled up the floor like carpet. I know the framerail dimensions of the Chevy and the dodge are a few inches different but I'm sure I will be able to figure out some mounts for it.
Do you have a link for your 63 build? Sounds interesting!
This weekend was busy, but I managed to get SOME work done. I cut up the exhaust from my K5 and managed to piece it together to fit the new build. Flowmasters are installed and sound great! Now that the open headers are sealed up, I could pinpoint more of this grinding issue. Ends up being that I've narrowed it down to the clutch. I can see the clutch fork rattling pretty violently when I start the engine. My father in law is coming on Tuesday to help me get the tranny pulled to see what exactly is grinding. I know there can't be much going on in there, but who knows until it's apart!
-Kevin
Old 06-21-2010, 05:23 AM   #29
aerotruk63
aerotruk63's Avatar
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=397681
Old 06-21-2010, 03:36 PM   #30
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Good luck with the dead line. I know all to well about what you're going through. It can be a real pita sometimes. But it'll be worth it in the end!
Ryan
1969 Chevy milk truck
Old 06-22-2010, 08:06 AM   #31
propanemudtruck
Thanks Diesel! I'm only concerned with 2wd, brakes, steering, and all the vitals to keep the engine safe! As long as I can cruise in the dunes and just roll around in the sand I'll be happy with my progress!
-Kevin
Old 06-22-2010, 02:29 PM   #32
Dieselwrencher
That'll be pretty cool for sure!
Ryan
Old 06-24-2010, 08:12 AM   #33
propanemudtruck
The grinding problem is fixed! My pressure place is the diaphram type with the short bearing. My issue was that the fork was not clipped to the pivot point properly! Dumb me.... But she's quiet now and I will be able to continue the build! Yesterday I moved the cab back near the rear tires, removed the brake booster/mc and pulled the trans/t-case loose, found the issue, got everything assembled the way it was supposed to be, the trans and t-case back in then my father in law showed up to help me some. He finished welding the body mounts in place and helped with other little things. We moved the cab back in place, got the inspection/PTO covers back on the transmission and found a couple bad plug wires from the old race engine so we'll use the new ones from the blazer. We put the master cylinder back on along with the brake booster and tonight possibly we'll start on brake lines. I need to shorten my steering shaft then the blazer steering column will work good enough for now. We discussed using a set of gauges and ignition panel off one of the race cars, so we'll need to find those at his place. Soon I'll need to pick up me seats from his house too!
No real point in pictures, it's just rework for the most part
-Kevin
Old 06-24-2010, 04:40 PM   #34
Dieselwrencher
Atleast you're making progress!
Ryan
Old 06-28-2010, 08:05 AM   #35
propanemudtruck
Well it's looking like the deadline won't be met.
I faced reality last night and it's evident that time and money are short once again.
It's ok though, because I'm a single income father of two beautiful girls and a husband to an amazing wife who works harder than I do at home and I'd be selfish to put some old truck in front of what I've got with them!
We took our oldest daughter to her first mud bog last weekend and she got to ride in one of the big trucks a couple times and SHE was the first one in the big pit! She wanted to play in the mud so I took her down to get dirty up to her shorts
For the 4th of July I'm taking my wife canoeing and kayaking with a couple friends because we don't get out enough and need some peaceful uhmdrinking time with adults.
My deadline was supposed to be in time for our family vacation up north but the sand will be there next vacation and the truck should be done by then.
-Kevin
Old 06-28-2010, 09:19 AM   #36
Patsfan34
Patsfan34's Avatar
Hey man, I'm glad I checked your plow build. Awesome progress and awesome work! Now if I could only get my wife out in the garage to help I'm sure I'd save a boat load of time! Have a great 4th of July!'
Patsfan34 is offline   Reply With Quote
Old 06-28-2010, 10:46 AM   #37
propanemudtruck
I guess it helps when that's where she grew up. 3rd generation circle track racer, I lucked out with her! Good luck with your build, it looks like you're off to a nice start
-Kevin
Old 06-29-2010, 10:15 AM   #38
propanemudtruck
Well all things considered, I'm still trying to get things done on the truck. Due to our family's schedules and racing, the 9th of July we will start our new roof on the house instead of using the weekend for the truck. That's pretty important though, I hate seeing homes turn to junk because of neglect.
Last night after the girls went to sleep I worked on my steering column mounts. The 71 column is trashed and I have a good K5 tilt column, so that'll work for now. The new style columns definitely take up valuable space under that small dash! I had to hack up the 71 and the 89 mounts on the pedal assys to make things come together. It's scabbed in place and with some gussets I think it'll fit just great in it's new home. I'll have to rework the clutch pedal again but that's why we do what we do!
Question for anyone, would two stainless hose clamps work for the firewall mount to keep the column in place? They seem to work in my driveway but wouldn't want something simple to cause a safety hazard with 8' blades on the truck...
I planned on using the electrical from the blazer to run all the controls and lights, but I think I'll just make a wire harness for the lights that jumps into the column controls and use an ignition harness from one of the old race cars. This year the truck won't have a radio and most likely will have two heater options - on or off Wiper options will be a must for plowing so I'll have to see how good of shape the original setup is.
-Kevin
Old 06-30-2010, 11:13 PM   #39
jbclassix
Junk Yartist
jbclassix's Avatar
I like 4x4 builds!!
jbclassix is offline   Reply With Quote
Old 07-01-2010, 06:14 PM   #40
propanemudtruck
Originally Posted by jbclassix View Post
I like 4x4 builds!!
Just because they're easier to change the oil, right?
Unless I get a second 67-72 just for summer months, I can't see why it would be smart to built a 2 wheel drive... I was thinking though, it sure would be cool to find a running/driving C20 out west next year to haul my donor body back to Michigan! How fun would that be to drive american iron across the great Route 66?
-Kevin
Old 07-01-2010, 10:39 PM   #41
jbclassix
Junk Yartist
jbclassix's Avatar
You have no idea how much weight that holds!
Old 07-06-2010, 06:29 PM   #42
68 TT
Still plays with trucks
68 TT's Avatar
You have your priorities correct. The girls and your family come first, just like they should.
Good progress considering how little time you have to work on it.
I am in the same boat. Two little girls, very little time and hardly any money to spend on the project.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-23-2010, 12:14 PM   #43
propanemudtruck
Not much progress on the truck, I've been busy with the new roof on the house and we just got back from the family vacation... But while we were in Pen****er, MI my wife found a matched set of 71 plates that we'll be able to use once we get this thing ready for the road! No pictures, but they're pretty much rust/corrosion free, just a bit on the back of one of them. It was $5 for a rusted out single plate, $15 for a nice single plate or $25 for the set we got. I think it was a pretty good deal for a classic plate set, not knowing the going rates for actual use! Hope to get the roof finished after all the rain and get back on the truck to get it going.
-Kevin
Old 11-07-2010, 12:29 AM   #44
propanemudtruck
I actually have an update! I was cleaning a bit around the driveway tonight and decided to throw the wooden box up on the frame to see how it will fit. It's dark out but here are some pictures of how my Mater's lookin...
-Kevin
Old 11-11-2010, 02:27 PM   #45
propanemudtruck
-Kevin
Old 11-11-2010, 02:42 PM   #46
timjt
Looks great, wish I had the time and money to do that
timjt is offline   Reply With Quote
Old 11-15-2010, 11:14 AM   #47
propanemudtruck
Me too... It'll sit until spring time now. But it was fun rolling it down the driveway into the yard and sitting in the driver's seat! Made me wish I had a garage to keep it in and keep working...
-Kevin
Old 03-11-2011, 01:49 PM   #48
propanemudtruck
I'm so excited to get going again on this, we've got our flight booked to So. Cal and I'm looking at trucks online... If only May could be over, we would be home already and the progress would continue... Can't wait!
-Kevin
Old 03-14-2011, 05:31 AM   #49
propanemudtruck
http://67-72chevytrucks.com/vboard/s...d.php?t=452450
Found A Good Clean C10, looks like I've got another project and STILL need a good body for the plow rig! Bummer, eh?
-Kevin
