Old 06-26-2010, 06:47 PM   #1
edflores
thinking out loud...Trailing arm Xmember question
Im looking to see if you could move the trailing arm crossmember up to change your wheelbase from long to short.
Then chop the frame off somewhere behind it and do a custom backhalf.
Just a thought..
edflores is offline   Reply With Quote
Old 06-27-2010, 09:03 AM   #2
SCOTI
SCOTI's Avatar
Re: thinking out loud...Trailing arm Xmember question
Sure you could. Anything is possible w/the right plan, tools, & skills.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-27-2010, 09:16 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im sure that would be very do able make it easy on yourself and buy an aftermarket trailing arm crossmember put it in the frame where you want it and build the back half off that..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-27-2010, 12:15 PM   #4
edflores
Was looking at the one from nate.
But I just wanted to see if anyone had done it before. Seems easier than shortening the frame for what I want to do with the truck.
Old 06-27-2010, 04:41 PM   #5
raycow
Someone else asked the same question recently because he didn't want to deal with moving the cab mounts. I don't know if he ever got an answer.
It looks like it should be doable, but I'm not sure if it will actually be less work overall. You will still have to deal with the spring mounts, box mounts, rear crossmember and a few other bits I probably forgot about.
Ray
raycow is offline   Reply With Quote
Old 06-29-2010, 12:28 AM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
for someone like myself (can weld but not gonna weld my frame together lol)
it SEEMS like it'd be easier to drill holes and cut rivits VS cutting frame/welding back..
idk free bump interesting..
I HATE RIVITS THO
John
1999 Toyota Tacoma 4x4
Old 06-29-2010, 07:48 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Just a thought..
They did it with project "Get Shorty" in Custom Classic Trucks magazine.
They moved the crossmember forward to eliminate messing with the rear cab mount,... but they still had to cut the frame.
Look here for the articles:
Frame cut
http://www.customclassictrucks.com/t...ech/index.html
Trailing arm crossmember moving
http://www.customclassictrucks.com/t...uck/index.html
To me this would be more trouble than taking out the 12" of frame under the cab,... and slicing 8" off the rear frame rails.
Keith
Convert to disc brakes.
Old 06-29-2010, 07:53 AM   #8
lolife99
lolife99's Avatar
This is the entire set of tech articles for that project truck.
http://www.customclassictrucks.com/s...les/index.html
Keith
Old 06-29-2010, 12:12 PM   #9
edflores
As i am bagging the rear, Im trying to weigh the pros and cons of doing it this way. Im still going to have to kick up the frame, still have to make bag brackets, shock crossmembers.
And I mean cut off the factory frame. not splice it back on.
Old 07-07-2010, 01:57 AM   #10
edflores
Any more input? I just bought a short bedsides so I need to get my game plan soon.
Old 07-07-2010, 10:29 AM   #11
SCOTI
SCOTI's Avatar
Your plan is a home built back half frame section using the OE truck arms as the rear suspension?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-07-2010, 11:24 AM   #12
edflores
Well not a full backhalf yet. I think I can get away with using the frame as usual, just everything will be a foot forward. I will use a non contoured notch on whats left behind later. I plan on a 5-7" or so rear drop on bags now. And my stock arms, for now, maybe upgrade to Nates in the future.
Im not going to be using the coils, I have "hats" for the upper bag mount, I have an aftermarket shock xmember, and was going to get a longer adjustable panhard bar.
Old 07-11-2010, 05:01 PM   #13
sjarrett71
sjarrett71's Avatar
I think what you're asking has been talked about before. The problem with your plan is the contours and width of the frame changes and that is why people cut their frames on the flat parts and move everything forward. In other words, if you just move the trailing arms and axle forward it will no longer sit under the humps and look pretty silly.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-13-2010, 03:40 PM   #14
edflores
I dont have a SWB 63-72 i could compare to, but shouldnt the frame be the same pretty much from the front, to where the trailing arm Xmember attaches on a SWB to the same point on a LWB?
Old 07-13-2010, 07:47 PM   #15
SCOTI
SCOTI's Avatar
The frame rails are for the most part straight in the area mentioned. On swb frames, the TA c.member is under the cab. On lwb frames, it's behind the cab. From the front of the bed toward the back is where the frame curves out.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-21-2010, 01:21 PM   #16
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Having shortened several LWB frames, I agree! It is pretty straight forward and easy to shorten one.
Here are the dims for a SWB frame FYI.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-21-2010, 01:59 PM   #17
edflores
Thanks for your input.
What would you charge for that service?
What should I pay to have someone cut my frame down, if i bring a rolling chassis?
I dont see harm in me trying first to bolt up the trailing arm xmember.I'm going to by a PB one this month. This thing will be bagged, so bag mounts, relocated shocks, and longer panhard are needed regardless. the rear bed mounting looks to be the other issue, but i dont see it being a major problem.
Old 07-21-2010, 02:20 PM   #18
glock35ipsc
The last few I did I charged $450, and they were happy to pay that. Good SWB frames are a rare breed in these parts, so when you do find one in good shape the owner wants a mint for them, so shortening the more available LWB frame is usually more cost effective.
I'm not going to try to talk you out of doing it your way, because it will work. But, me personally, if I were to see it at a show, I'm that irritating guy that would be shaking his head going "why did he do it that way??" It would be obvious to an enthusiast that knew what things should look like under there that it was done in a weird way. But building these things are done to the builder's satisfaction, not the onlookers.
Don't take this as a slam against you, its not. I'm just trying to give you my reasoning why I would rather shorten the frame in the middle -vs- moving the x-member up. It should be all about what you want, not us.
Bob
Old 07-22-2010, 09:25 AM   #19
boostin20
boostin20's Avatar
Sub'd
boostin20 is offline   Reply With Quote
Old 07-22-2010, 08:21 PM   #20
edflores
If i could find someone to accurately do it for 450, I'd cut the frame. And leave with a smile. Thanks for your input.
