06-29-2010, 02:51 PM | #1 |
C60 parts for a C10
What parts of a C60 will be usable on a C10? I am trying to figure out what parts I should grab from the one in the yard here. Right now I am going to get the Driver's door, Grill and hood lights, but is there other stuff I should get too?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
06-29-2010, 03:19 PM | #2 |
1961 crewcab
Re: C60 parts for a C10
the whole cab will interchange,- doors all the dash (pretty much anything that bolts to the cab)
hood grille, but you will need to switch out the headlight/grill supports with those of a c10. check for a tach, or air guage in the dash, both of those =$$$!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-29-2010, 03:21 PM | #3 |
I know there is no Tach, but I will check for an air gauge.
06-29-2010, 03:55 PM | #4 |
1961 crewcab
the other stuff I saw that looked good was that 2bbl and oilbath air cleaner and bracket on the blue 65c10.. not a huge desireable item, but if someone was going full resto they are hard to find I think..
I have also seen people looking for that altenator bracket too, usually you don't see a complete engine like that in a yard...
