Old 06-29-2010, 09:56 PM   #1
rwolf9653
more ideas than money
rwolf9653's Avatar
P0343 code
I scanned my 2003 Suburban 6.0 for a check engine light and got this:
P0343 Camshaft Position Sensor A, Bank 1
I have two questions though:
1. Which side is this? Passenger or driver?
2. I take it that there is one sensor for each cam, so would it be cost effective to just change them both as a just in case?
I have searched the web and found about 75% say it is passenger side, and 25% say it is drivers side. I am better with points than I am sensors and ECM's.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 06-29-2010, 10:35 PM   #2
clinebarger
Re: P0343 code
Your 6.0 only has One cam sensor & One camshaft. Its behind the intake manifold (remove the intake so you can remove all the debris from around the sensor). You chould have a bad connection/short/open curcuit in the CMP sensor wiring.
clinebarger is offline   Reply With Quote
Old 06-29-2010, 10:51 PM   #3
rwolf9653
rwolf9653's Avatar
Re: P0343 code
Thank you. As soon as you said one cam I said
I get too worked up when it comes to these computer controlled engines!
Randy
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1987 Chevy V10
2003 Chevy Suburban
