06-30-2010, 09:12 AM | #1 |
Brake questions
On my 56 I have a disk, drum setup. I have the blue and red check valves. My ?s are do I mount the valves before or after the splliter block. I also want to run a hyd brake switch do I mount it to the line going to the front or rear brakes.
06-30-2010, 11:13 AM | #2 |
Active Member
Re: Brake questions
I assume you used a disc type master cylinder with 2 seperate reservoirs and 2 out put lines. You should also have a disc drum combination (proportioning) valve. Connect the brake light switch in the rear cicuit after the combination valve, then connect the 10lb residual valve. Connect the 2lb residual valve in the front brake line directly after the meeteing valve.
Danny Nix CPP |
