06-28-2010, 10:55 PM | #1 |
Lift kits?
Dont mean to write a book here but I searched the forums and didnt really find what i was looking for. I am wanting about 6 inches of lift on my '76 shortbed 4x4, but need opinions on how to go about doing it. My original plan was to get front springs, blocks, sway bar drop brackets and extended brake lines but 6'' blocks in the rear just dont seem like a good idea to me. Should i just fork out the extra $$$ for the rear springs? Will Lift springs in the rear ride better than blocks? And are the "EZ Ride" or "Soft Ride" kits really better than standard kits? The front springs on my truck are sagged so much that the springs hit bump stops on just about every bump so anything will ride better.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-29-2010, 06:27 AM | #2 | |
Re: Lift kits?
"Front springs and blocks" is far more of an issue than anything. You do NOT want blocks in the front, ever. Just get a 6" spring in the first place.
As far the rear, there are a couple of way to go. The most economical way is with a 2" add-a-leaf and a 4" block. It kind depends upon how hard you intend to drive this truck. If it is mostly street with occasional light off roading, this way is fine. Or you could go with a full 6" spring lift in the rear, for harder off-road use. I would not even consider running a 6" block though, the leverage is just too much. You will get wheel-hop problems.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-29-2010, 09:28 AM | #3 |
Re: Lift kits?
Most 6" lifts will consist of 6" springs for the front and 4" blocks for the rear. That way the truck sits level
don't forget to get a drop pitman arm. Last edited by baclay9; 06-29-2010 at 09:32 AM. |
06-29-2010, 11:30 AM | #4 |
Re: Lift kits?
Check out www.offroaddesign.com . I've used the shackle flip kit with good results. You can add a leave or use a longer shackle to get up to 6" without replacing your rear springs. They have pretty much everything you could need, including front springs, steering correction parts, shocks, brake lines etc.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
06-29-2010, 12:22 PM | #5 | |
Re: Lift kits?
06-29-2010, 12:57 PM | #6 |
Re: Lift kits?
6" lift springs up front.
2" lift springs in the rear with a 4" shackle flip (http://www.offroaddesign.com/catalog/shacklekit.htm). I would also suggest a steering box brace..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
06-29-2010, 12:57 PM | #7 |
Re: Lift kits?
I'm still a little confused on what exactly the shackle flip kit does. Does it just move the shackle to the other side of the spring?
06-29-2010, 01:35 PM | #8 |
Re: Lift kits?
The stock set up has the shackle going UP from the mount to the leaf spring. The shackle flip has the shack going down to the spring, adding lift.
stock the leaf spring end is 4" (approx) above the shackle mount, swap it to 4" below the shackle mount and you get 4" of lift. When you move one end of the leaf spring, lift is 1/2 the amount the spring end moved. 4" above + 4" below=8" / 2= 4". Did I confuse you more?
06-29-2010, 02:11 PM | #9 | |
Re: Lift kits?
06-30-2010, 03:23 PM | #10 |
Re: Lift kits?
Does anyone know if a 4" lift will be high enough to clear 35's or is it better to go with the 6"?
06-30-2010, 04:04 PM | #11 | |
I know the pieces fit
Re: Lift kits?
2.5" lift will clear 33's, 4" will clear 35's. 6" over 35's is gravy. |
06-30-2010, 06:00 PM | #12 |
Re: Lift kits?
Is there an advantage with the shackle flip instead of lift springs?
06-30-2010, 06:14 PM | #13 |
Re: Lift kits?
more flex and softer ride.... my vote goes to a 4 inch lift.... DIY offroad B52 kit in the front and shackle flip in the rear... smooth sailing from there on out...
06-30-2010, 08:04 PM | #14 |
Re: Lift kits?
Can i ask why you would go with a 4"?
06-30-2010, 09:34 PM | #15 |
OL BLUU
Re: Lift kits?
If I remember right.... if you go more than 4" you have a lot more issues to work around and fix; With 4" you dont have to extend your brake lines or adjust your drive shaft angle. With that said... I stopped at 4" with my 4x4 Blazer I had... and it cleared the 35's on 8" rallys just fine. BUT I also did not do any off roading either...
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
06-30-2010, 10:40 PM | #16 | |
Re: Lift kits?
06-30-2010, 11:21 PM | #17 |
OL BLUU
Re: Lift kits?
I'm not for sure with the above set up you mentioned... this is what I did on my 84' Blazer: 4" lift springs and steering drop arm in front, and the back was a simple 4" block. No other adjusts where needed anywhere as a I recall as I installed it myself.
