Grandpa in the rustmobile...
Should i have primered my motor?
Fresh out of the hot tank i painted my motor with some cheap primer. Then i was planning on hitting it with 500* orange paint. Heres some pics
of what im using. Ive heard both, dotn use primer, use primer. Should i scrape the primer off and do striaght paint OR get a better primer? Ive got too much $ in this to half do it and have it flake off in a month. Thanks! should i have used the etching primer on the block? Someone help me I dunno what Im doing thanks!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
What?
Re: Should i have primered my motor?
I've done a few engines, and I have never used a primer spray before applying the engine paint. Just the high heat engine enamel paint. Never had an issue with it "going bad" in one way or the other.
Personally, I'd be worried that the cheap or non high heat primer would cook off in the hotter areas of the engine. Maybe not flake, but burn the engine paint to a brown color or something of the like. Just my .02
Chris 1968 K20 Suburban 1972 K10 LWB PU |
![]() Join Date: May 2009
Yeah, you've got a high heat engine enamel but, the primer isn't high heat. i think the primer will burn off in places and in turn the top coat will fail.
Probably easiest to wash the primer off with lacquer thinner.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
#4 | ||
"I ain't nobody, dork."
I've never used an engine primer. Just 4 to 6 coats of Chevy Orange.
Gary
#5 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
Location: Aurora,Il ..born,raised and still live in the same house
spray it with mineral spirits or thinner and powerwash it off, then hit it with about 3 coats of high temp. chevy ORANGE engine enamel.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
"THE GREEN GOBLIN"
I agree with above That is a cheap primer, If you were going to primer it I would have used Dupli-Color high heat Paint, Enamel with Ceramic Resin, Flat, Gray Primer, is designed to withstand temperatures of up to 1,200 degrees F.. then your top coat will have more of a chance of lasting long without flaking later. I just went with Por15 ENGINE-ENAMEL it hasn't flaked yet and it looks good but then again I went with their Black.
http://www.por15.com/ENGINE-ENAMEL/productinfo/EEPA/
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Wash that primer off with thinner and put several coats of the duplicolor. I use automotive acrylic enamel on all my engines. It shines like new money and seems to hold up great.
i've used duplicolor primer on engines and also just the duplicolor with no primer and have seen no difference in the final product or how long it lasts
that primer id just wipe it off with laquer thinner soaked rag or shop towels
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 07-02-2010 at 09:21 AM. |
![]() Join Date: Jan 2008
X-2 I use automotive enamel and have had no problems at all. It cleans real easy and lasts!
Ok looks like im wiping my primer off with laquer thinner and doing straight up 500* chevy orange, thin coats 15 min. between coats. Then get thicker.
Thanks guys! PS, its got the pistons crank cam timing chain etc in it., no powerwashing lol
If you can afford it POR engine paint is the route to go. I have used all of the other spray can types and while it works ok for a while, the POR is there to stay. Leddzepp was the reason I went with POR the first time and I will never use anything else again on anything I want to look good for more than a few weeks.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#13 | |
Under Construction
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
im going go have to try some of this por stuff lol everyone says its great
i got the primer off and washed it with brake cleaner let it dry and sprayed 2 cans of 500 degree orange paint. post pics later
