Does anyone know or recognize these Gauges?
I recently purchase a truck which has these digital gauges, but they are all out of whack.
The Gas gauge is stuck on 42 gallons! The Temp. gauge goes from 40 to 680 Fahrenheit! The Speedometer is not working at all! I need to find out who what company made them to see if I can find a replacement sensor or a fix as I want to keep them, but obviously in working condition. Does anyone recognize them?? |
Re: Does anyone know or recognize these Gauges?
remind me of dakota digital guages maybe these are their early style gauges?
They look straight out of KIT from knight rider.
Cyberdyne:
1) i have them and love them. 2) i will try to assist asap but have to run to work, in the meantime you might try their website for tech info. http://www.cyberdynegauges.net/ Last edited by C-10 simplex; 07-01-2010 at 08:24 PM. |
X2 on Cyberdyne
Thanks a Millon for the info! You guys are the BEST!!!
![]() Join Date: Dec 1999
Yep I actually have two of the lower ones still in the box I would have to look and see which ones they are if anybody is interested?
So anyways, these gauges should not be any more difficult to hookup than any other type of gauge; The speedo would need the ESS----electronic speed sender which plugs into the transmission where the conventional speedo cable would normally plug in.
You'll probably have to contact their tech support for the other stuff..... P.S. alot of people rag on digital speedometers and gauges but one advantage is that you can switch gear ratios and tire sizes on a whim and the speedo can be (relatively) easily recalibrated; You don't have to screw with different speedo drive gears and such. Last edited by C-10 simplex; 07-02-2010 at 02:37 PM. |
