I currently have a 69 Chevy C10 2wd. It has a saginaw three speed on the tree. The original motor was a 292. The engine is out and I have a mildly stock 350 for now to put in. Is this tranny able to handle it. Im going to a four speed or auto enventually. But I want to drive it now. How much power can this tranny handle. Your help is appreciated. Brian Wolf
Seasonal Poster
Ya i had the same thing in mine for a while, i bagged on it pretty good and it lasted 6 six years before it died and i put in the 4-speed, and that was only the time i owned the tranny. It should be able to easily handle it.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Fabricate till you "puke"
The saginaw 3spd will handle a fair amount of guff,& should work fine for street use. For drag strip use , I would say no......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Progress = 0%
Hey Brian,
You still owe me $60.00!!! Pay up!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#5 | |
HAHAHA!!! becareful, daddy wolf might make a return |
