07-04-2010, 11:31 PM | #151 |
Re: 1966 Chevy SWB Gasser influenced truck
Bag brackets tacked in
NEXT: 1. finish welding and cross support for upper bag brackets. 2. clean and paint rear chassis, run rear wiring and rear brakelines GETTING REAL CLOSE I CAN SMELL THE BURNT RUBBER
I LOVE BURNOUTS:metal NO BOZO's |
07-04-2010, 11:33 PM | #152 |
Senior Enthusiast
Very cool video!
07-04-2010, 11:49 PM | #153 |
DOWN!
Front: DROPMEMBER (stock fenderwhells) 25.80" tall tire Rear: stock trailing arms, 2" blocks, PORTERBUILT crossmember,PORTERBUILT custom notches.PORTERBUILT bag brackets. 29.5" tall tire
07-05-2010, 01:27 AM | #154 |
Killer!!!
CHEVY ONLY |
07-05-2010, 08:53 AM | #155 |
67-72 parts collector,…
VERY nice!
07-05-2010, 12:05 PM | #156 | |
That's one bad ass truck!!!
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
07-05-2010, 05:14 PM | #157 |
welding
07-05-2010, 05:18 PM | #158 |
I would say you could mow your lawn with this truck....but it appears you have a maintenance free lawn
CHEVY ONLY |
07-06-2010, 04:53 PM | #159 |
progress
07-09-2010, 10:38 PM | #160 |
fresh paint
Getting close
07-11-2010, 10:12 AM | #161 |
chevy only
very cool glad to see ya on it again, and the weather is perfect to br in the garage
CHEVY ONLY... Nothin Else ! |
07-13-2010, 01:22 PM | #162 |
07-13-2010, 01:40 PM | #163 | |
I used a seat out of a 91 as well... You do sit lower and yes way more comfortable. got it reupholstered with the diamond pattern.
07-18-2010, 10:40 AM | #164 |
Having driveshaft clearence issues. Gonna try to work some more magic!
New 1-piece drive shaft $185. New 2-piece drive shaft $420. Honestly thought one piece would be ok. GONNA SUCK IF I HAVE TO BUY A 2-PIECE AFTER I ALREADY BOUGHT THE 1-PIECE. Note to self always do a 2-piece driveshaft(FIRST).
07-18-2010, 10:52 AM | #165 |
Can't get enough of this truck ese!!!
07-18-2010, 10:58 AM | #166 |
Resistance is Futile
Nothing a sawzall shouldn't be able to take care of!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-18-2010, 11:00 AM | #167 | |
07-18-2010, 12:17 PM | #168 | |
07-18-2010, 12:27 PM | #169 | |
07-18-2010, 10:51 PM | #170 |
I always say" sawzall solves all problems"
1-PIECE DRIVE SHAFT IN Rolled truck in and out of garage. no binding or rubbing with rear bags deflatted.
07-19-2010, 12:29 AM | #171 |
chevy only
nice to talk to ya today jeff,stoked about rolling to the show together i am going to talk to the other jeff (protrash)about going too
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 07-19-2010 at 12:29 AM. |
07-19-2010, 08:40 AM | #172 |
1961 crewcab
I would just do a tiny C notch on that cab brace over the driveshaft, there might be a little flex in the frame, and the rubber cab mounts to make it touch every now and then... that is if it is driveable with the bags all the way down...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-25-2010, 04:52 PM | #173 |
RIDE HEIGHT! This is how truck to sit all the time.
FILTHY DIRTY TRUCK!!!!!!!! Pic of driveline bed support mod.
07-25-2010, 04:56 PM | #174 |
OPEN HEADERS, NEEDS TO BE TIMED AND ITS REAL RICH
07-25-2010, 05:01 PM | #175 |
Tot Roddin'
That turned out real nice!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
