Old 07-05-2010, 12:49 PM   #1
Mean 69
Wheel Lug Base Circle, 5 on 5 Only?
My wife recently inherited a solid 74 GMC stepside, which we are going to keep in the family and go through (completely). I'll post some shots once we get moving on it, but I was looking at it over the weekend and was puzzled by something. The truck currently has aftermarket wheels, which we are going to replace with something a little "cooler," and I confirmed that the base circle on them is 5 on 4 3/4", NOT 5 on 5" which is what I thought all 1500's came with? This is actually good news as I have a set from a different project that will fit, but begs the question is the truck had been previously modified. I haven't pulled the wheels off to check into it more, thought I'd post the question for the experts here.
Did the light duty GMC's indeed come with the 5 on 4 3/4" base circle, or is there more to the story on this truck?
Thanks!!!
Mark
Mean 69 is offline   Reply With Quote
Old 07-05-2010, 01:25 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Wheel Lug Base Circle, 5 on 5 Only?
It should be 5 on 5. All 1/2 tons were, AFAIK.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-05-2010, 01:39 PM   #3
68longhorn
68longhorn's Avatar
never seen a 5 lug truck that wasn't 5x5
68longhorn is offline   Reply With Quote
Old 07-05-2010, 01:46 PM   #4
cableguy0
Gm 5 lug truck is 5 on 5. There was never another pattern used. 5 on 4.75 is car pattern. Theres no way it came from the factory with anything but 5 on 5. It could have been converted at some point but thats not something normally done on an otherwise stock vehicle. Are you sure your measuring properly? https://www.rsracing.com/tech-wheel.html
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-05-2010, 02:11 PM   #5
texasfunk
texasfunk's Avatar
i dont remember exactly where, but i read the rotors off of a early 70's van fit these trucks, and they were indeed 5x4.75, and some changed them out for different wheels, not sure about it, but remember reading it somehwere.
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 07-05-2010, 02:23 PM   #6
cableguy0
Nope the vans are the same as the truck. They have been since they went to 5 lug in 71.Even astro vans are 5 on 5. The wheels all interchange between trucks,vans and astro vans.
Old 07-05-2010, 02:29 PM   #7
Rollinsqrbdy
Rollinsqrbdy's Avatar
So just curious what other vehicle has the same bolt pattern as ours?
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 07-05-2010, 03:38 PM   #8
Slonaker
Slonaker's Avatar
Caprice, Impala SS.
Slonaker
EDIT: There was some discussion here recently where it was mentioned that some Jeeps used 5X5 pattern.
Stock '01 Silverado
Old 07-05-2010, 03:49 PM   #9
Mean 69
Thanks guys, that is essentially what I thought as well. I'll have to pull the wheels off and see if someone redrilled, etc. I measured using a tape measure, so not horribly accurate but did verify with a 5 on 4.75 wheel that I had, same result. I also took one of the axles from my Camaro project (also 5 on 4.75...) and stuck it in the lug openings on one of the wheels on the truck, it seemed to line up perfectly well, but there is a possibility that the cold beer that was accompanying me yesterday affected my accuracy!!
In the end, my plan is to use the CPP modular drop spindles, initially with the stock brakes and then move into a set of 13" Wilwoods for this package. When I was looking at the Wilwood site, they too showed 5 on 5 for the hubs that come with their kits. So, if someone did some monkey business on the fronts, then my concern is that I won't be able to use the CPP drops with what is currently on there. The Wilwood brake hats are a dual bolt pattern, but the hubs with their kit doesn't show that it is or could be drilled for the smaller base circle, I am guessing it probably can though (most of their hubs are dual or even triple drilled).
Funny, I was looking at the truck and commenting on how simple a project it was going to be, haven't made to step one without a funky issue though!!!!
I'll report the findings back, but I am 99% certain that the wheels are 5 on 4.75. Yippee, sleuth work!
Mark
Old 07-05-2010, 05:07 PM   #10
LONGHAIR
Unless you took the wheel directly off of a car and put it onto the truck, no measuring involved.....I am willing to bet on mis-measuring. It is very common with 5 lug wheels.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-05-2010, 05:23 PM   #11
junkyardjohn
junkyardjohn's Avatar
ALSO MID 70 LINCOLN MXIIIIs. I'VE GOT A 9" THAT I HAD A POSSI CENTER SECTION & NEW RING & PINION W/A 350-1 RATIO PUT INTO IT. THEY HAVE REAR DISCS ALSO. IT'S GOING INTO MY NEVER ENDING MONEY PIT SHORT FLEET 72 PROJECT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-05-2010, 08:21 PM   #12
68longhorn
68longhorn's Avatar
Caprice, Impala and all other GM b-body cars were 5x5 from 71-76 then again in 91-96. They were 5x4.75 from 58-70 and 77-90.
Old 07-06-2010, 12:09 PM   #13
dropd80s
dropd80s's Avatar
Also Im pretty sure the caprice wagons and 9C1s in the 77-90 time period were 5x5 also.
dropd80s is offline   Reply With Quote
Old 07-06-2010, 03:30 PM   #14
68longhorn
68longhorn's Avatar
.My mistake, wagons, electras, caddies( not sure of model) were 5x5 those years. Still never seen a 5x4.75 truck tho.
Old 07-06-2010, 10:47 PM   #15
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
actually my mom used to drive a swb chevy van, think it was either a 74 or 75, and it was 5x4.75 lug pattern from the factory. i had a old camaro project at the time and put the original rims from it on the van since they had good tires. i was really puzzled too, i thought they were all the same as the truck, but i was wrong. ill have to do some part number searchin on this one, because im interested in at least knowing what it takes to swap to this pattern on our trucks. but i do remember doing the front brakes and having to buy one rotor and yes it was 5x4.75 too.
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
Old 07-06-2010, 10:52 PM   #16
knightowl73
oh yeah, and also, ive had a 78 cadillac seville. they are 5x5 pattern, and 76-79 were RWD with disc brakes. they are based on a Nova platform so they are a little bit narrower, but thats good if your tryna tuck in some 10's out back, and m pretty sure most all of them were 3.73. i figured ths was some pretty good info for someone else to lock in.
Old 07-06-2010, 10:56 PM   #17
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
If you measure center to center its 4.75.. but thats not the correct way to measure the bolt pattern on a 5x5 pattern. why, dont know. the correct way to measure it is top of the wheel stud to the center of the other... kinda dumb but some genius though of it .... the 6 lug folks measure center to center... normal people... haha. When I redrilled my rear rotors, I should have measured 2x and drilled once.. lol
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-07-2010, 12:23 AM   #18
7T2
Active Member
7T2's Avatar
It's because you're measuring the diameter of the circle created by the center of all the lugs. You measure the ones opposite each other on an axle with an even number of lugs, because they are directly across from each other. You can't do this on a 5 lug axle because none of the lugs are directly opposite each other. Luckily, if you put a tape measure on the end of one lug and measure to the center of the one that is two lugs away, you will get the correct measurement.
see here for visual reference:
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 07-07-2010, 02:43 AM   #19
knightowl73
ok just verified, the van was a 73 van and even autozone and orielly websites list them as being 4.75 pattern. for $33 a piece id try them if i was going that route for some wheels i had already or somethn. would be so much easier and safer than adapters and even cheaper than redrilling them... as far as the back i guess the b-body 77-90 rear would work for ease of things. just a bit of weldng the perches on. i bet itll work....and dangit got me really thinking now. I can get ahold of plenty more wheel sets with the car pattern.
Old 07-07-2010, 02:53 AM   #20
texasfunk
texasfunk's Avatar
Knew I was somewhat right, I knew I reAd somewhere it was only two years or something, iirc 73-74
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 07-08-2010, 12:39 PM   #21
dropd80s
dropd80s's Avatar
Old 07-15-2010, 02:47 PM   #22
Mean 69
Team, thanks again for the input here. I looked at it again, and I'll tell you, I am still not sure but believe that it probably is a 5x5 and that I measured incorrectly. Quarter inch diameter really is a small amount, so I need to pull a wheel and try it that way.
Just wanted to reiterate thanks for the input!
Mark
