Old 07-04-2010, 09:41 PM   #1
oldspowered
resto body guy
tbi questions?
hey guys i finally got my tbi motor in my 71 super now i got questions...
i have a good 87 c-10 computer wiring harness all the way back to fire wall inside the firewall is where the 87 got all burnt up. so basically have the compter harness and that is it! how can make this with out spending 400 dollars for a painless wiring kit? can i plug this into the stock 71 wiring?? if not would it be smart to snag another dash wiring from a 73-87 truck?
i have got all my fuel pump and etc. figured. i just need advice on this part!
i'm trying to do this low buck as my funds are tight.
thanks,
David
http://i3.photobucket.com/albums/y86...DSC_0004-2.jpg
trucks are ment to haul!
oldspowered is offline   Reply With Quote
Old 07-05-2010, 01:25 AM   #2
capev86
Re: tbi questions?
you need the complete wiring harnesses for both. all you need from the tbi truck is the engine harness and computer harness. the power feeds/ box and lighting will be kept from the 71 harness, unless you want a modern style fuse box.
capev86 is offline   Reply With Quote
Old 07-05-2010, 06:23 AM   #3
oldspowered
resto body guy
Re: tbi questions?
the computer and engine harness are the same loom the fuse panel and all the fuses ect is the under the dah and which got burnt from my 87. just trying how to figure this out on how to wire it in and have everything work.
Old 07-05-2010, 11:15 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Re: tbi questions?
I am working on the same swap in my 67. I planned on getting the newer under dash harness and using it. Should be pretty straight forward. Lots of power circuits and under dash stuff that the TBI engine and ECM need and that will take care of it.
I am planning on using the square body tilt column with delay wiper / cruise on the turn signal control stalk too. I'm sure it will take some fabrication work but I will make it fit.
Just need to figure out where to put the check engine light so it doesn't look out of place.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-05-2010, 02:30 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: tbi questions?
You could always use the space for the vacuum guage
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
