I need an air ride suspension kit!
So I'm ready to dive into air bagging my 68. My question is what is a good complete air suspension kit that will provide me with all peices I will need. I know there are some vendors that specialize in this on this forum and maybe someone can direct me to them. Thanks for your help.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: I need an air ride suspension kit!
What kind of budget are you working with? ($$$)
Do you have to rebuild the front suspension also? (balljoints, bushings, etc) Does your truck have disc brakes already? Give us a little more info.
It does have front disk brakes. This is more of a show truck and I don't take it out to often. I just need a basic set up that can make it go low but doesnt really need to lay frame. As far as replacing joints, etc, is that common when adding air? I want to be the setup and then find a shop to install for me. Thanks for your help.
![]() Join Date: Jun 2006
Talk to Nate @ Porterbuilt-http://porterbuiltstreetrods.com/site/
I would look around in the suspension section.
x2 on the Porterbuilt suggestion. He can fix you up with everything you need. Since you have disc brakes,... I would also add drop spindles. That's a cheap 2.5" of drop.
Nothing to see here.....
![]() Join Date: Jun 2007
Porterbuilt is first rate. I bought much of my system from Suicidedoors and was very happy.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
iam also interested in air ride and was wondering what kind of money i would have to spend i have disc brakes on the front and 2 1/2 drop spindels the rest of the front end is stock on my 68
thanks for any help |
JRods Garage
I went with ***************** for almost everything on my truck and it ran me something like $1500. There are a few other things im gonna add to the truck to get the front down a little more. Here are some pics from my build
![]() ![]() ![]() ![]() ![]() I am hitting my diff on my bed, so the rear is as low as Im gonna get without mods. I had to notch the frame. The front is getting some tubular control arms, but I have 2.5" drop spindles, front bag brackets for the stock control arms, Slam Specialties bags, dual Viar compressors, dual 3 gal tanks, SMC 8 valve setup(1/2" valves), AVS switchbox, and some other crap, but I cant remember... |
