Closed Thread
Old 07-05-2010, 02:24 AM   #426
CaliBoyRoll1971
Re: What did you do to your truck today!
Currently deployed but mother and Father-in-law did her up and put her in the 4th of july parade.
1971 c-10 350 Longbed
1942 jeep willies
1948 dodge truck
03 jeep liberty
05 1500 4wd chevy
CaliBoyRoll1971 is offline
Old 07-05-2010, 10:43 AM   #427
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by Lippyp View Post
Even with the cap off its hitting the firewall enough to push the top forward and stop me dropping it in I think its engine mount bodgery. I've decided to go with a Pertronix conversion kit for the Mallory as its nearly new and a flamethrower coil, should be here tomorrow. Coil is a black one so it should dissaper on the firewall a little and it'll be relocated a bit more out of sight and rewired anyway.
I had that problem on a car once. Turned out they had the wrong transmission mount and crossmember in there and the engine was tilted down in the back too far. It was just enough you couldn't even get the distributor out of the engine without jacking up the tail end of the trans.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline
Old 07-05-2010, 10:50 PM   #428
Hubscrub
Cruzin
Hubscrub's Avatar
installed driver door panel, and hauled some wood, drove around
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 07-06-2010, 12:07 AM   #429
07SSSC
07SSSC's Avatar
Washed the exterior, wiped down the interior and cleaned under hood. Took it for a quick drive, first drive in 3 weeks, running good. Gonna have to pull the engine and fix some major oil leaks though, may even put a standard pressure pump back in it, getting tired of it puking oil every time I drive it.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 07-06-2010, 12:19 AM   #430
btullis99
btullis99's Avatar
installed a ton of parts, 4.10 gears with an eaton trutrac differential, monster transmission 700r4, and got my david boyd aluminum gas tank under the bed, plumbed, and wired. what a difference on the performance, went from a tired th350 with 2.73's to all those new goodies. it was a good 4th weekend!!
btullis99 is offline
Old 07-06-2010, 12:27 AM   #431
67-72trucks
I started wet sanding and blocking my 72 gmc cab inside and out- Painting it this weekend DBC Black base coat,PpG dc 4000 clear coat..Will post some pictures.
67-72trucks is offline
Old 07-06-2010, 08:05 AM   #432
1968ratrod
1968ratrod's Avatar
put my 69 on jack stands and pulled all the wheels, its time for a full brake job
1965 Chevy Suburban
2003 Chevrolet S10
2011 Harley Streetglide
1968ratrod is offline
Old 07-06-2010, 12:35 PM   #433
Indyuke
Changed the engine and rear differential oil. Mobile 1 fully synthetic.
Next is the tranny fluid and filter.
Indyuke is offline
Old 07-06-2010, 01:38 PM   #434
68 TT
68 TT's Avatar
Modified my square body K10 frame to make it fit the 67 cab structure better by moving the back of cab frame arch 10" rearward and cut it down in length a little to place the tires where I want them relative to the 67 body wheel arches.
The cab now sits 2" lower in the back and can align with the bed without the need for a 3" body lift as is typically done with this swap.
Just need to get the truck into my driveway where it can be leveled out then I can secure the bed in place and fabricate the cab mount brackets to fit the new cab location. Hopefully I can get that done in the next weekend or two.
After that is done I can move on to the fun part of retrofitting the more modern drivetrain and accessories then tackle the rust repair & body work.
First pic is before the frame mods, second pic is after (the bed & cab are just set in place and need to move forward a little in the second pic).
68 TT is offline
Old 07-09-2010, 01:10 AM   #435
treveiger
treveiger's Avatar
Looked for trannys and info on them for hours.
treveiger is offline
Old 07-10-2010, 09:43 AM   #436
marks1972
marks1972's Avatar
Did a compression check on the engine had 140-150 lbs on each cylinder except one. On number 4 I only had 130 lbs. As long as I had the spark plugs out I put new ones in. Old ones only had about a hundred miles on them but I wanted to try the accel header plugs. Made a big difrence on how close the wire boots are to the headers about a half inch.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline
Old 07-10-2010, 10:00 AM   #437
71tahoe
71tahoe's Avatar
Saturday getting ready to work on the frame and cab, I installed new tires, wheels and adjustable suspension...
...on the ghetto welding cart.
After pic with the prior wheel/tire combo next to it.
Name:  welding cart 001.jpg
Donor vehicle.
Name:  welding cart 002.jpg
71tahoe is offline
Old 07-10-2010, 10:06 AM   #438
Hubscrub
Cruzin
Hubscrub's Avatar
fixed the steering yesterday, and ordering parts today
Proverbs 3:5,6
Hubscrub is offline
Old 07-10-2010, 12:08 PM   #439
shopking72
shopking72's Avatar
Went and got some new rear tires this morning. Went with BF Goodrich 275/60/15. I think they look a lot better. I am getting 245/60/15 for the fronts soon... They are 235/75/15 right now.
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 07-10-2010, 03:29 PM   #440
btullis99
btullis99's Avatar
new brake booster, master cylinder, and a wilwood proportioning valve.
Old 07-10-2010, 08:38 PM   #441
davebloomer
davebloomer's Avatar
finished up my cam/head/stall converter install yesterday and burned a lot of rubber today!
davebloomer is offline
Old 07-10-2010, 10:47 PM   #442
pat 70/71
pat 70/71's Avatar
Thank you for your service! today I washed my fleet side truck and drove it to a cruise night it rained ! lots of fun to see the guys with the (not for rain cars) stayed about 20 minutes & drove home it was good times cheers, Pat
pat 70/71 is offline
Old 07-10-2010, 11:04 PM   #443
chevy_mike
Never Ending Projects
chevy_mike's Avatar
What I did today...
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 07-10-2010, 11:08 PM   #444
vectorit
What?
vectorit's Avatar
Flushed the cooling system (been in the 100's here lately).
Bleed the brakes.
Washed/detailed.
Loaded up ice chests, and the canopy.
Parked snugly in her garage, anxiously waiting to show off at the Brothers truck show early tomorrow morning!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-11-2010, 01:26 AM   #445
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Took my 71 4x4 out for a nice long 150 mile shake down ride. Had a fantasic ride. Nice to have it on the road.
oldiron is offline
Old 07-11-2010, 06:24 AM   #446
OhioDan
OhioDan's Avatar
Talking Re: What did you do to your truck today!
Finally finished stereo install yesterday, going to install carpet today.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline
Old 07-11-2010, 11:09 AM   #447
packrat42
packrat42's Avatar
Went to a cruise inn,
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline
Old 07-11-2010, 11:55 AM   #448
Davetopay
Went to the coin op car wash and got most of the crud off from camping last week. Also pressure washed the goo left behind by my old leaky steering box out of the wheel well.
Still need to give it a once over before state inspection tomorrow, and adjust the clutch.
Davetopay is offline
Old 07-11-2010, 03:16 PM   #449
Crazyz28
I drove mine home from work for the first time ever. Get to drive it back to work tomorrow and put new tires on it, bleed brakes, and finish hooking up a few more things before I started driving it every day.
'72 Chevy Longbed 327 w/ 3 on the Floor-soon to be DD
'71 GMC Longbed (originally bought project, now parts truck for '72)
'94 Camaro Z28 cam/exhaust/gears
'02 Chevy Impala-DD for now
-Ryan, GM Master Technician
Crazyz28 is offline
Old 07-11-2010, 04:51 PM   #450
Dano69c10
Dano69c10's Avatar
I worked on the '70 2day.
I replaced the leaking thermostat gasket with a Fel-Pro Perma Gasket.
Finished installing a Heartthrob exhaust system, but I have a leak at the manifold.
I cleaned off the millions of spider webs and dusted off the truck.
Started it up for the first time this year. It started no problem, fired right up. I love these trucks!
Too bad I couldn't have it ready for the Brothers Truck show today.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Closed Thread
