Old 07-06-2010, 10:38 PM   #3
tucsonjwt
Re: I want a.c.,opinions on stock vs aftermarket
If Vintage Air gets you out of vacuum controls, then go for that. My stock A/C causes the vacuum operated cruise control to cut out when the A/C is on high and nobody can figure out why. Also, the connector to the fan switch is worn out, causing the fan to be intermittent - so I think you would be better off if you can go with a new electronic HVAC control.
tucsonjwt is offline   Reply With Quote
